this my sequence
class sl_seq1 extends slave_sequence;
`uvm_object_utils(sl_seq1)
function new (string name=“sl_seq1”);
spi_seq_item seq;
virtual task body();
seq=spi_seq_item::type_id::create("seq"); //create the seq item
start_item(seq);
assert (seq.randomize() with {spi_miso inside {[0:1000]};})
`uvm_info("seq1","seq1 was randomised in between 0 to 1000",UVM_MEDIUM)
finish_item(seq);
endtask :body
endclass :sl_seq1
this is my monitor code
`define MON spi_mon.spi_mon_cb
class spi_monitor extends uvm_monitor;
`uvm_component_utils(spi_monitor)
virtual wb_intf vif;
spi_seq_item txn;
uvm_analysis_port #(spi_seq_item) spi_port;
function new(string name=“spi_monitor”,uvm_component parent);
super.new(name,parent);
//super.build_phase(phase);
spi_port = new(“spi_port”,this);
if (! uvm_config_db #(virtual wb_intf) :: get (this, “”, “vif”, vif))
`uvm_fatal (get_type_name (), “Didn’t get handle to virtual spi interface in monitor”)
super.run_phase(phase);
txn=spi_seq_item::type_id::create(“txn”,this);
uvm_info( get_type_name(), "Going to collect spi seq item sample in monitor", UVM_MEDIUM) forever begin collect_data();
uvm_info( get_type_name(), “spi seq item sample collected in monitor”, UVM_MEDIUM)
spi_port.write(txn);
task collect_data();
//#20;
txn.ss_pad_o=vif.`MON.ss_pad_o;
wait(vif.MON.wb_adr_i=='h10) //CTRL REGISTER ADDRESS begin if(vif.
MON.wb_dat_i[8]) //GO_BSY==1
//for lsb=1
if (vif.`MON.wb_dat_i[11]==1) //LSB will go first from miso
//tx_neg=0 [10](mosi=rising edge) rx_neg=1 [9](miso falling edge)
if(vif.`MON.wb_dat_i[9]==1 && vif.`MON.wb_dat_i[10]==0)
if(vif.`MON.wb_dat_i[6:0]==0) //CHAR LEN==0
int x=0;
repeat(128)
@(negedge vif.`MON.sclk_pad_o)
txn.spi_miso[x]=vif.`MON.miso_pad_i;
@(posedge vif.`MON.sclk_pad_o)
txn.spi_mosi[x]=vif.`MON.mosi_pad_o;
x++;
if(!vif.`MON.wb_dat_i[6:0]==0) //CHAR LEN !=0
for(int i=0;i<vif.`MON.wb_dat_i[6:0];i++)
txn.spi_miso[i]=vif.`MON.miso_pad_i;
txn.spi_mosi[i]=vif.`MON.mosi_pad_o;
//tx_neg=1 [10](mosi= negedge) rx_neg=0 [9](miso posedge)
if(vif.`MON.wb_dat_i[9]==0 && vif.`MON.wb_dat_i[10]==1)
int x=0;
repeat(128)
x++;
end //LSB=1 end
//if LSB=0
if (vif.`MON.wb_dat_i[11]==0) //MSB will go first from miso
//tx_neg=0 [10](mosi=posedge) rx_neg=1 [9](miso negedge)
int x=127;
repeat(128)
x--;
for(int i=vif.`MON.wb_dat_i[6:0];i>0;i--)
//tx_neg=1 [10](mosi= posedge) rx_neg=0 [9](miso negedge)
int x=127;
repeat(128)
x--;
end //LSB=0 end
end //GO BSY end
end //CTRL end
