hi,
Iam new to uvm
i didn’t able to get port,import,export,implementation,analysis?
initiator,target,producer consumer
someone help me with with explanation and example
thank you
hi,
Iam new to uvm
thank you
In reply to sudharshan:
https://verificationacademy.com/cookbook/analysisport
https://verificationacademy.com/sessions/how-tlm-works
hi,
Iam new to uvm
thank you
Sudharshan,
There are a number of examples in the UVM-Connect package showing
producers as TLM2 intiators, consumers as TLM2 targets,
and analysis ports.
Most of these examples are centered around cross-language
(SystemC, SystemVerilog) TLM connections. However, there are
one or two examples showing just native SystemVerilog connections.
Additionally there’s a fairly good “TLM primer” that comes
with the UVM-Connect documentation (see docs/html/index.html
docs/UvmConnectPrimer, or docs/TLM_REVIEW.txt).
Specifically an example you can start with is examples/connections/sv2sv_native.sv).
You’ll find the last-released UVM-Connect v2.3.1 package on this
Verification Academy.
– johnS
