Hello seniors, please let me know what is wrong when i am creating driver class
ifndef r_agent define r_agent
include"uvm_macros.svh" include"w_config.sv"
include"r_driver.sv" include"r_sequencer.sv"
`include"r_monitor.sv"
class r_agent extends uvm_agent;
`uvm_component_utils(r_agent)
r_config rcfg;
r_driver rdr;
r_sequencer rsqr;
r_monitor rmon;
extern function new(string name=“r_agent”,uvm_component parent);
extern function void connect_phase(uvm_phase phase);
// New construct
function r_agent::new(string name=“r_agent”, uvm_component parent);
super.new(name,parent);
// BUILD Phase
function void r_agent::build_phase(uvm_phase phase);
if(!uvm_config_db#(r_config)::get(this,“”,“r_config”,rcfg))
`uvm_fatal(“TB CONFIG”,“can not get() wcfg from uvm_config”)
rmon=r_monitor::type_id::create(“rmon”,this);
if(rcfg.is_active==UVM_ACTIVE)
rdr=r_driver::type_id::create(“rdr”,this);/// ERROR ERROR ERROR
rsqr=r_sequencer::type_id::create(“rsqr”,this);
//////// COnnect Phase
function void r_agent::connect_phase(uvm_phase phase);
rdr.seq_item_port.connect(rsqr.se_item_export);
`endif
///////////////////////////////////////////////// ERROR/////////////////////////////////////////////////////////////
** Error: C:/Users/BAVITH KUMAR/Desktop/SRAM_UVM/r_agent.sv(46): Failed to find name ‘type_id’ in specified scope
In reply to uvm_verification:
It indicates that you haven’t registered your driver with the factory using uvm_component_utils().
