I am working on module level verification of a counter(up/down counter).
I am looking at handling asynchronous initial reset on environment side. In my case, i just need to make sure that the sequences are sent only after the reset becomes false.
My reset generation in top file and the driver looks as below:
module tb_counter_top;
//reset Generation
reset = 1;
#5 reset =0;
#5 reset = 1;
#100;
//---------DRIVER---------
super.run_phase (phase);
initialize(); //initialise the driver signals
drive();
seq_item_port.item_done();
end //forever
endtask : run_phase
virtual task drive();
@( counter_vif.counter_cb);
if (counter_vif.reset ==1) begin
counter_vif.counter_cb.load_counter <= req.load_counter;
counter_vif.counter_cb.count_value <= req.count_value;
counter_vif.counter_cb.up_counter <= req.up_counter;
counter_vif.counter_cb.run_counter <= counter_vif.clk_en;
end //if
Though the driver is not sending the sequences if reset is true, but sequences are generated. If i am setting load_counter or other control signals in the first sequence, this info is not passed onto to DUT/scoreboard because of reset.
One simple way is, I will send the default values in the first sequence and send the required values in the subsequent sequences. Even if the first sequence is ignored because of reset, there wont be any loss of any important control signals.
Can we use reset phase to wait for reset to become false?
Or wait for reset to be false before calling seq_item_port.get_next_item(req);? (@(posedge counter_vif.reset) before calling get_next_item)
What is the better solution?
