I dont understand how to use two analysis ports. In my case I have to compute the output at a particular valid signal but send it to scoreboard after a delay of three clock cycles based another signal flag.
This is how i am currently implementing using the buffer approach but i am curious to know how to implement using two ports to create a new class of trasaction then use that newly created to class trasaction as temparory storage to store the prev transaction
instead.
class normal_add_ref_monitor_after extends uvm_monitor;
`uvm_component_utils(normal_add_ref_monitor_after)
jelly_bean_transaction jb_txm;
jelly_bean_transaction jb_txm_q[$];
virtual simpleadder_if jb_vi;
uvm_analysis_port#(jelly_bean_transaction) ref_mon_a_port_after;
function new(string name="normal_add_ref_monitor_after",uvm_component parent);
super.new(name,parent);
endfunction :new
void'(uvm_resource_db#(virtual simpleadder_if)::read_by_name(.scope("ifs"), .name("simpleadder_if"), .val(jb_vi)));
ref_mon_a_port_after=new("ref_mon_a_port_after",this);
endfunction:build_phase
jb_txm=jelly_bean_transaction::type_id::create("jb_txm");
@(posedge jb_vi.clk)
if(jb_vi.valid == 1) begin
jelly_bean_transaction jb_txmq = new;
jb_txmq.a = jb_vi.a;
jb_txmq.b=jb_vi.b;
jb_txmq.c=jb_txmq.a +jb_txmq.b ;
// add_mon_ref_add_result();
jb_txm_q.push_back(jb_txmq);
$display("queue = %p",jb_txm_q);
if(jb_vi.valid_out == 1) begin
jelly_bean_transaction jb_txmq = jb_txm_q[0];
ref_mon_a_port_after.write(jb_txmq);
`uvm_info("input_pop",$sformatf("value: %0d", jb_txm_q.pop_front()),UVM_LOW);
end // forever begin
join
endtask:run_phase
endclass:normal_add_ref_monitor_after
