Got an Error while using set_type_override_by_type
Hi All,
While using the type overriding I got an error. Issue is the "newly added analysis port is not a class item ". Please help me to resolve the Issue.
The code as follows:
//Base monitor
  class base_monitor extends uvm_monitor;
   `uvm_component_utils(base_monitor)
   //declaration of variables and analysis ports
     super.new(name,parent);
   endfunction : new
   endfunction : build_phase
    //connections
   endfunction : connect_phase
      //code
   endtask : run_phase
endclass : base_monitor
// extended monitor
class ext_monitor extends base_monitor;
   `uvm_component_utils(ext_monitor)
   //new analysis port declared
   uvm_analysis_port #(seq_item) pkt_port;
     pkt_port = new("pkt_port", this);
   endfunction : new
endclass : ext_monitor
class base_agent extends uvm_agent;
	uvm_active_passive_enum is_active = UVM_ACTIVE;
	`uvm_component_utils(base_agent)
	base_driver driver;
	base_sequencer sequencer;
	base_monitor monitor;
           if(is_active == UVM_ACTIVE) begin
              driver = base_driver::type_id::create("driver",this);
              sequencer = base_sequencer::type_id::create("sequencer",this);
           monitor = base_monitor::type_id::create("monitor",this);
endclass : base_agent
class ext_agent extends base_agent;
  `uvm_component_utils(ext_agent)
  function new (string name = "ext_agent", uvm_component parent = null);
  endfunction : new
endclass : ext_agent
class module_env extends uvm_env;
  `uvm_component_utils(module_env)
  ext_agent active_agent;
  ext_agent passive_agent;
  function new(string name = "module_env", uvm_component parent = null);
  endfunction : new
    uvm_config_int::set(this,"active_agent","is_active",UVM_ACTIVE);
    uvm_config_int::set(this,"passive_agent","is_active",UVM_PASSIVE);
    active_agent  = ext_agent::type_id::create("active_agent", this);
    passive_agent = ext_agent::type_id::create("passive_agent", this);
    super.connect_phase(phase);
  function void end_of_elaboration_phase(uvm_phase phase);
    super.end_of_elaboration_phase(phase);
  endfunction : end_of_elaboration_phase
endclass : module_env
class top_env extends uvm_env;
 `uvm_component_utils(top_env)
 module_env env;
 scoreboard scbd;
   // Overriding
   set_type_override_by_type(base_monitor::get_type(),ext_monitor::get_type());
   env = module_env::type_id::create("env",this);
   scbd = scoreboard::type_id::create("scbd",this);
   env.active_agent.monitor.pkt_port.connect(scbd.pkt_import); // I am getting the Issue: "pkt_port is not a class item"
endclass : top_env
Thank you
In reply to Kanth:
All of the connections made need to refer to the base classes. In this case, it would be ‘base_monitor’. Since pkt_port only exists in the extended ‘ext_monitor’, the connect phase has no knowledge of this port, hence the error.
Typically, extended classes will only change the behavior of an object or component, either by an added constraint or additional checks. You won’t be able to add any additional exports/imports as the base class has no access to these.
In reply to cgales:
Thank you Mr.cgales
