Global timeout value
           What is the global timeout value for uvm_environment.
How we have to fix that one.
ex - Set_global_timeout()
Regards
Venkatesh
In reply to Muthuvenkatesh:
Global timeout is the maximum limit of simulation execution. This determines the end-of-test timeout. The default value of timeout is set to 9200s.
One can also use run time plusarg +UVM_TIMEOUT=, to set the timeout value.
Refer to this page for more information on UVM_TIMEOUT from command line processor.
In reply to sharvil111:
The current versions of UVM are using set_timeout.
The UVM requires the Implementation of at least 1 objection mechanism to stop the simulation. If something goes wrong with the objections the set_timeout stops the simulation after the time used for this.
Agree. I read the doc and corrected the answer. Thanks!
