I have to set the configuration object from the lower component such as driver to assertions module, as I have many assertion checks based on the fields in the configuration object.
And it is working fine. I want the assertion module to be reused.
Is there any other best method to achieve this, considering the reuse-ability of the assertions module ???
I do not see a problem regarding the configuration object when you are re-using the assertion module. Of course you have to follow the name rules you have defined. I see the problem more regading the interface signals/variables. I’d recommend to use the generic interface approach in the assertion module. The code looks like this:
module assertions(interface if);
logic data;
data = if.x;
This means you can connect to any interface which has variable x. The name of the interface is not relevant.
Lets say, I have a variable ‘STATE’ in the configuration object. It is not possible to get the STATE information from interface, so I will be using the config object to check the value of STATE and depending on this value, only a certain set of assertions are checked. Similarly. I have many such checks depending on other variables.
If I reuse the assertion module in another test-bench environment, the config object may not be similar to the one which I have in my present environment. How to minimise this dependency?
I’m already using the generic interface signals as you can see the port list of my assertion module, along with that I need the config information to enable/disable some set of assertions.
