Getting a config db variable value in higher hierarchy
In my Env class, I am setting a variable through uvm_config_db and accessing it in higher hierarchy i.e one of the sequences to form a case.
class env extends uvm_env;
typedef enum bit {ERROR_FROM_SEQUENCE=0, ERROR_FROM_CALLBACK } err_gen_src;
err_gen_src error_source;
      uvm_config_db#(int)::set(this, "*", error_source, ERROR_FROM_SEQUENCE);
Now can I do something like this in Case?
class my_seq extends uvm_sequence#(item);
   task body();
      item t;
         p_sequencer.fifo.get_peek_export.get(my_req);
         **case(uvm_config_db#(int)::get(this, "", error_source, ??)**
            **ERROR_FROM_SEQUENCE:** `uvm_do_with(item, {item.data == 100;})
            **ERROR_FROM_CALLBACK:** `uvm_do_with(item, {item.data == 300;})
         endcase
In reply to smukerji:
Your sequence does not belong to the hierarchy of your class-based testbench. It is simply a transient object that will be generated at any time and disappear at another time.
The uvm_config db has no limitations regarding the directions.
What you are doing in your sequence Looks a Little bit strange, especially
and this
The question marks are not legal.
Please explain what your intention is.
Thanks for pointing out. I didnt know what to put there, so a question mark. My intention is to have a config variable called error_source of type enum in the environment class and use it in my sequence, to decide what sequence to send to sequencer. The value of the error_source is used as a Case switch.Is there any way to implement that?
The line
I got from
http://www.verilab.com/files/mastering_reactive_slaves.pdf
OK, I understand. It Looks like you do not understand the mechanism of the uvm_config_db. You do not store variables there. You store simple values of certain types. The value is assiciated with a name. The Name consists of the path and a simple Name (string). In your case the simple name is ‘error_source’. And the path is the concatenation of ‘this’ and an empty string. Where you have the question marks you have to use a local variable where the value will be stored in.
So, then this should work?
case(uvm_config_db#(int)::get(this, “”, “error_source”, error_source))
ERROR_FROM_SEQUENCE : uvm_do_with(item, {item.data == 100;}) ERROR_FROM_CALLBACK : uvm_do_with(item, {item.data == 300;})
endcase
In the set command you have also to use a string as the simple name:
      uvm_config_db#(int)::set(this, "*", "error_source", ERROR_FROM_SEQUENCE);
This presumes ERROR_FROM_SEQUENCE is the value you want to put to the config_db.
Hi Chr_sue,
We cannot directly use uvm_config_db#(int)::get(this, “”, error_source, ??) in the sequence. Am I correct?
I think it needs to be accessed by replacing m_sequencer instead of “this” in the above statement.
Please correct me if I am wrong.
In reply to mbhat:
Of course, you can do this as shown inmy last Reply. It depends always how you are doing the set.
Please read the following link for seperate solutions:
https://verificationacademy.com/cookbook/config/configuringsequences
