Is it possible to printout the name of a type including the parameters that defined the type?
get_type_name() seems to print out the base class, even though I used `uvm_object_param_uitls()
In reply to raysalemi:
Not when you use the `uvm_object_param_util macros. See http://go.mentor.com/mcem for an alternative.
Hmm…I didn’t see the answer there. Did I miss it?
