Hi guys,
I’m struggling with get() from fifo…I’m trying to compare the items get from
this is my code
int unsigned counted_request;
int unsigned counted_received;
uvm_tlm_analysis_fifo #(frame_sync_item) profile_ref_fifo;
uvm_tlm_analysis_fifo #(traffic_profile_item) profile_dut_fifo;
data_item data_item_collected_trans;
data_item profile_ref_fifo_trans;
traffic_profile_item traffic_profile_item_collected_trans;
traffic_profile_item profile_dut_fifo_trans;
data_item_collected_trans = data_item::type_id::create("data_item_collected_trans");
profile_ref_fifo.get(data_item_collected_trans);
counted_request ++;
// Sampled reference profile:
profile_ref_fifo_trans = data_item::type_id::create("profile_ref_fifo_trans");
profile_ref_fifo_trans.acm_prof = data_item_collected_trans.acm_prof;
traffic_profile_item_collected_trans = traffic_profile_item::type_id::create("traffic_profile_item_collected_trans");
profile_dut_fifo.get(traffic_profile_item_collected_trans);
counted_received ++;
profile_dut_fifo_trans = traffic_profile_item::type_id::create("profile_dut_fifo");
profile_dut_fifo_trans.acm_prof = traffic_profile_item_collected_trans.acm_prof;
uvm_report_info(get_name(), $sformatf("%d) TX == REFERENCE -> prof = %p", counted_request, profile_ref_fifo_trans.acm_prof), UVM_LOW);
uvm_report_info(get_name(), $sformatf("%d) RX == DUT -> prof = %p", counted_received, profile_dut_fifo_trans.acm_prof), UVM_LOW);
The code for comparison is after the upper one.
It’s seems that after some forever cycles the value get from REF fifo is the one of the previous cycle…
this is the output, where, for example, in step 3 reference modu should be 6.
Something I don’t understand with get() tasks?
@ 1508788.75 ns: 1) TX == REFERENCE → prof = '{enabled:'h0, cod:'h1, mod:'h5, power:'h1, traff:'h0}
@ 1508788.75 ns: 1) RX == DUT → prof = '{enabled:'h0, cod:'h1, mod:'h5, power:'h1, traff:'h0}
@ 1558228.75 ns: 2) TX == REFERENCE → acm_prof = '{enabled:'h0, cod:'h1, mod:'h4, power:'h1, traf:'h0}
@ 1558228.75 ns: 2) RX == DUT → acm_prof = '{enabled:'h0, cod:'h1, mod:'h4, power:'h1, traff:'h0}
@ 1607666.25 ns: 3) TX == REFERENCE → acm_prof = '{enabled:'h0, cod:'h1, mod:'h4, power:'h1, traff:'h0}
@ 1607666.25 ns: 3) RX == DUT → acm_prof = '{enabled:'h0, cod:'h1, mod:'h6, power:'h0, traff:'h1}
@ 1657106.25 ns: 4) TX == REFERENCE → acm_prof = '{enabled:'h0, cod:'h1, mod:'h0, power:'h0, traff:'h1}
@ 1657106.25 ns: 4) RX == DUT → acm_prof = '{enabled:'h0, cod:'h1, mod:'h4, power:'h1, traff:'h0}
If i comment the line
outputs are correct…
