I am developing a generic adapter in RAL which will suit for all protocols.Also creating generic sequence item for adapter. My intention here is generic adapter should act as plug-play method. Now I need to know how to cast protocol sequence item with generic sequence item.
In reply to Priscilla:
I’m not sure if this is a good idea, because this requires parameterized classes with a big amount of parameters. This makes the usage complicated.
Why do not use a UVM Framework Generator to generate your specific UVM testbench for your application?
Hi chr_sue,
Where can we get a UVM FrameWork Generator ?
JeffD
In reply to dvuvmsv:
Hi Jeff, there are a couple generators on the market, commercial and free-of-charge. Mentor has the UVMF which is in my eyes an overkill, generating to much things around.
The best I know ist the EasierUVM Framework Generator from Doulos.
It is accomplished with UVM coding guidelines.
See here: Doulos
I know this generator best because it is based on my personal one. It is simple, very flexible and of course free of charge.
Jeff,
You can download all versions of the UVM Framework from the Verification Academy. Link to the page is here: https://verificationacademy.com/topics/verification-methodology/uvm-framework
