Generating Register Tracker File
Is there a way in UVM to generate/create the register tracker file, which have the following information in the printed log file for every Read or a Write access to the Register set(RAL) during the entire simulation.
| Time | Reg Name | Reg Field | Sequence(which initiates the Write/Read) | Access Type(FrontDoor/BackDoor) | Previous Value | Value to be Written|
In reply to azherkhan2431:
Currently, there is nothing inbuilt, which can print as per your mentioned requirement. but you can do it in your environment explicitly.
