Generate pattern using constraints
Generate pattern using constraints where
R-red with range [0:15]
G-green with range [16:30]
B-blue with range [31:50]
Pattern is RGBBGR?
In reply to patil shweta:
I guess R, G, and B representing an enumertaion type. And R, G, and B are representing exactly 1 value, respectively. The range might indicate the width of the enumeration type.
Hello patil shweta!
Here is the code I’ve tried till displaying the colors and their respective ranges twice.
//Generate pattern RGBBGR
class packet;
	rand enum {R,G,B} color;
	rand int range;
	constraint c_RGB {
			if (range inside {[0:15]}) {
						color == R;
			if (range inside {[16:30]}) {
						color == G;
		        if (range inside {[31:50]}) {
					        color == B;
	constraint c_range {range inside {[0:50]};}
        constraint c_pattern_dist {range dist {[0:15]:/2, [16:30]:/2, [31:50]:/2};}
endclass: packet
module pattern;
	initial
			packet pkt = new;
			$display("\nThe pattern is as follows:");
			repeat (6)
					pkt.randomize;
					$display("\n%0s \t%0d",pkt.color.name,pkt.range);
endmodule: pattern
You can use post-randomization for the pattern.
I don’t think anyone understood your question. Is “range” a value or range of bits in a larger vector? Can you give declare the variables you want randomized and give some example values that would meet the constraints you are looking for?
In reply to Shashank Gurijala:
if i change the pattern to display ,these code will be same?
Sorry, I didn’t get you.
But patil shweta, I only coded till you obtain 2 R’s, G’s and B’s respectively and not in the order you asked for which is RGBBGR.
If I given pattern like RGBBRGB,THESE code will be same for that pattern
You haven’t explained your problem with the necessary details. Can you show declarations the variables you want randomized and give some example values that would meet the constraints you are looking for?
