function bit [7:0]payload_calc payl(int length,int data_size,int data[]);
payl = new[length];
reg [31:0][7:0] temp_data;//varible(packed array) used to to convert 256 bit data in to 8 bit form
int a =0;
reg [7:0] temp_payload[];
temp_payload = new[length];
for(int i=0;i<data_size;i++)begin
temp_data = data[i];//data is 256 bit array
for(int j=0;(j<32 && a<length);j++)begin
temp_payload[a] = temp_data[j];
`uvm_info("TEMP_PAYLOAD",$sformatf("temp_payload[%0d] : %0h",a,temp_payload[a]),UVM_HIGH)
`uvm_info("TEMP_DATA",$sformatf("tmp[%0d] : %0h",j,temp_data[j]),UVM_HIGH)
a++;
payload_calc= temp_payload;
endfunction : payload_calc
i want a function which return the array … but i trying the above one which shows compilation error…how to overcome this error
module top;
`include "uvm_macros.svh"
typedef bit [7:0] byte_da_t[];
function byte_da_t payl(int length,int data_size,int data[]);
byte_da_t temp_payload;
logic [31:0][7:0] temp_data;//varible(packed array) used to to convert 256 bit data in to 8 bit form
int a;
payl = new[length];
a =0;
a++;
return temp_payload;
