I am trying to implement changes to my Test bench to accomodate on the fly reset so it can complete/kill what it is doing. The general idea is from this paper.
UVM_FATAL @ 1010: uvm_test_top.env.agt.sqr [uvm_test_top.env.agt.sqr] Item_done() called with no outstanding requests. Each call to item_done() must be paired with a previous call to get_next_item(). I am assuming the below code is supposed to take care of this.
while(seq_item_port.has_do_available()) begin
req.status = UVM_TLM_INCOMPLETE_RESPONSE;
seq_item_port.item_done();
break;
Follow up question, how do we restart the sequence in the test after the second time reset is high?
@(posedge vif.rst_n);
if (!vif.rst_n) begin
vif.pwdata <=0;
vif.paddr <= 0;
vif.pwrite <=0;
// vif.hsize <= 0;
// vif.htrans <= 0;
vif.psel <=0;
vif.pstrb <=0;
`uvm_info ("driver","Entering here",UVM_NONE);
if(tr != null) begin
tr.status = UVM_TLM_INCOMPLETE_RESPONSE;
I see 2 problems here:
(1) You are synchronizing on the rising edbe of rst_n (reset comes out of reset). And you are continuing by checking if vif.rst_n is low
This should not happen, because after the rising edge of rst_n the signal is high.
(2) In this reset branch you are doing a
Thank you. I fixed the seq_item_port call and it fixed the issue. How about my follow up question? how do we restart the sequence in the test after it detected a reset in the middle of the test?
