Hi All,
I have a requirement, where I have to run same sequence again and again multiple times, but want to ensure that sequence got over.
Can you anyone tell me, if there is a way using which we can figure out sequence got over?
Hi All,
In reply to kmishra:
You can use simply loop construct to run your sequence several times in your body task like this
task body();
repeat (10)
`uvm_do(seq)
endtask : body
This will execute your sequence named seq 10 times.
You should not use the `uvm_do_* macros.
task body();
seq = my_seq::type_id::create("seq");
repeat (10) begin
if (!seq.randomize()) begin
`uvm_error(get_full_name(), "Randomization error!");
else begin
seq.start();
Why not to use `uvm_do?
