I have created UVM monitor. I am trying to extract the data and write it into a file but the problem is that the file does not get created. It should get created in the same folder in which i am creating the monitor.
Here is the code:
@(posedge vif.clk)
trans.valid_out <= vif.dut_clk.valid_out;
// if(vif.vip_clk.valid_out == 1) begin
fd = $fopen("data_txt", "w");
$fwrite(fd, "%b", trans.valid_out);
$display("valid_out=%d", trans.valid_out);
trans.ciphertext[0] <= vif.dut_clk.ciphertext[0];
$display("ciphertext=%h", trans.ciphertext[0]);
//end
There are a few weaknesses in your code:
(1) you should never use $display in your UVM code. Always employ the UVM reporting macros like `uvm_info etc.
(2) Writing in a file from your UVM code you should also use the uvm_action from reporting for writing to a file (UVM_LOG)
(3) If you want to write to a file you should open the file at the beginning of your simulation.
Never open the file somewhere in a task. This is legal but it is bad coding practice.
I was trying your code with the $fopen in the run_phase and it is creating the file data_txt.
Where are you creating an object of your transaction trans?
In reply to shankar_logic:
OK. But coming back to your code. Calling $fopen(“data_txt”, “w”); in each loop cycle creates always a new file. at the end of the current cycle you have exactly 1 entry. You lost all the other ones.
Is this the behavior you want to have?
Thanks for the help and finally the file got generated but i am not able to write the data into the file. I am using $write system task to write the data into the file.
virtual task get_and_drive(uvm_phase phase);
file = $fopen(“data_driver.txt”);
phase.drop_objection(this);
phase.raise_objection(this);
$cast(rsp, req.clone());
rsp.set_id_info(req);
drive_transfer(rsp);
seq_item_port.item_done();
virtual task drive_transfer(encrypt_seq_item trans);
@(posedge vif.clk) begin
$display(“i am here”);
vif.vip_clk.key <= trans.key;
vif.vip_clk.data <= trans.data;
$write(file, “trans.data”);
vif.vip_clk.valid_in <= 1;
trans.valid_out <= vif.vip_clk.valid_out;
$display("vif.vip_clk.data = %h", vif.vip_clk.data[0]);
$display("vif.vip_clk.key = %h", vif.vip_clk.key[0]);
$display("trans.valid_out= %d", trans.valid_out);
$display("vif.vip_clk.valid_in = %d",vif.vip_clk.valid_in);
vif.vip_clk.valid_in <= 0;
HAving a deeper look to your code I found a few weaknesses:
(1) It seems you are using a clocking block named vip_clk. Then you have to synchronize your code woth the clocking block instead of the clk signal of the virtual interface.
(2) You should use blocking assignments in your code.
Here is my code example which works for me.
apb_seq_item trans;
apb_seq_item trans_clone;
int fd;
`uvm_info(get_type_name(),"run_phase",UVM_MEDIUM)
trans = apb_seq_item::type_id::create("trans");
@(negedge vif.pclk)
$fwrite(fd, "%d\n", fd);
// insert the monitor protocol here
$cast(trans_clone, trans.clone());
`uvm_info(get_type_name(), {"write trans to ap \n", trans.sprint()}, UVM_HIGH)
ap.write(trans_clone);
endtask : run_phase
