Hi
I am doing factory override example that how to override it
but i have got error Bad handle or reference. please tell me why is that coming and where
code:-
include "uvm_macros.svh" import uvm_pkg::*; class pkt extends uvm_sequence_item;
uvm_object_utils(pkt)
rand bit [3:0] a;
rand bit [3:0]b;
function new(string name="pkt");
function void display(string c);
$display("a=%d,b=%d c=%s",a,b,c);
class prod extends uvm_component ;
`uvm_component_utils(prod)
function new(string name="",uvm_component parent);
super.new(name,parent);
pkt p;
prod pr;
uvm_blocking_put_port #(pkt) put_port;
put_port=new("put_port",this);
pr=prod::type_id::create("pr",this);
repeat(3)
p=pkt::type_id::create("p");
assert(p.randomize()with {p.a>1;p.b==10;});
p.display("prod");
put_port.put(p);
class prod1 extends prod ;
`uvm_component_utils(prod1)
pkt p;
repeat(3)
assert(p.randomize()with {p.a>10;p.b==12;});
p.display("prod1");
put_port.put(p);
class cons extends uvm_component ;
`uvm_component_utils(cons)
pkt p;
uvm_blocking_put_imp #(pkt,cons) imp_port;
imp_port=new("imp_port",this);
task put(pkt p1);
this.p=p1;
p.display("cons");
class wrapper extends uvm_component ;
`uvm_component_utils(wrapper)
cons cn;
prod pr;
prod1 qr;
pkt p;
cn=cons::type_id::create("cn",this);
qr=prod1::type_id::create("qr",this);
pr.put_port.connect(cn.imp_port);
function void end_of_elaboration_phase(uvm_phase phase);
factory.print();
class test extends uvm_component ;
`uvm_component_utils(test)
wrapper r;
prod::type_id::set_type_override(prod1::get_type(),1);
r=wrapper::type_id::create("r",this);
`include "uvm_macros.svh"
module top;
initial
run_test(“test”);
error:-
** Note: (vsim-3813) Design is being optimized due to module recompilation…
