Hi everyone. I’m having a problem when I try to connect variable number of agent’s driver with the same number of DUT ports.
My goal is to connect each driver with only one input port.
When agents are created in environment, I used uvm_config_db#()::set() method to associate current driver with corresponding port.
This is where i get fatal error, because, uvm_config_db#()::get() didn’t retrieve or couldn’t find port_id value in the database.
Here are my codes for env and driver.
// prrs_driver
class prrs_driver extends uvm_driver #(eth_pkt);
`uvm_component_utils(prrs_driver)
virtual prrs_if vif; // virtual interface handle
// queue for fetching data
eth_pkt pkt_queue[$];
eth_pkt pkt;
// port selection variable
int port_id;
function new(string name = “prrs_driver”, uvm_component parent = null);
// Driver build phase
if(!uvm_config_db #(virtual prrs_if)::get(this, “*”, “prrs_if”, vif))
`uvm_fatal(“NOVIF”,{“virtual interface must be set for: “,get_full_name(),”.vif”})
if(!uvm_config_db #(int drv_num)::get(this, "", "prrs_env", drv_num))
`uvm_fatal("NOVIF",{"Driver haven't received port_id value ",get_full_name()})
endfunction : build_phase
// Driving transactions
// Initialisation
vif.pi_read_req = 0;
vif.po_dout = 'h0;
`uvm_info(get_type_name(), $sformatf("Waiting for the driver to get data"), UVM_LOW)
seq_item_port.get_next_item(pkt);
drive_item(pkt);
seq_item_port.item_done();
`uvm_info(get_full_name(), $sformatf("%0t: Transaction done.", $time), UVM_LOW)
endtask : run_phase
endclass : prrs_driver
// prrs_env
class prrs_env extends uvm_env;
// UVM factory
`uvm_component_utils(prrs_env)
// Agent handle
prrs_agent m_agent[NUMBER_OF_INPUTS];
// Scoreboard handle
prrs_scoreboard m_scbd;
// Configuration object handle
prrs_config m_cfg;
int port_id = 0;
// Environment class constructor
function new(string name = “prrs_env”, uvm_component parent = null);
// Environment build phase
// Nunber of the agents is same as the number of DUT inputs
for(int i = 0; i < NUMBER_OF_INPUTS; i++)begin
m_agent[i] = prrs_agent::type_id::create({“m_agent_”,$sformatf(“%0d”, i)}, this);
`uvm_info(get_full_name(), $sformatf(“Agent %0d created at %0t ns”, i, $time), UVM_HIGH);
uvm_config_db #(int)::set(this, "m_agent[i].m_drv", "port_id", port_id);
port_id++;
m_scbd = prrs_scoreboard::type_id::create("m_scbd", this);
`uvm_info(get_full_name(), $sformatf("Scoreboard created at %0t ns", $time), UVM_HIGH);
endclass : prrs_env
I would apprecciate any kind of help or advice regarding this problem.
Thanks in advance. :)
