Can Factory override the uvm_sequence_item ?
Following code does not override the sequence item type used by the driver class.
set_type_override_by_type(mem_seq_item::get_type(), child_seq_item::get_type());
I can’t get the child_seq_item item in Driver. So I add child_seq_item csi; in the driver for a workaround.
child_seq_item csi;
Any clue why Factory override does not work ?
This is the code.
class mem_seq_item extends uvm_sequence_item;
rand bit [1:0] addr;
`uvm_object_utils_begin(mem_seq_item)
`uvm_field_int(addr,UVM_ALL_ON)
`uvm_object_utils_end
function new(string name = "mem_seq_item");
class child_seq_item extends mem_seq_item;
rand bit [7:0] A;
rand bit [7:0] B;
`uvm_object_utils_begin(child_seq_item)
`uvm_field_int(A,UVM_ALL_ON)
function new(string name = "child_seq_item");
Here is sequence
class mem_sequence extends uvm_sequence#(mem_seq_item);
class my_sequence extends mem_sequence;
child_seq_item child_item;
`uvm_object_utils(my_sequence)
function new(string name = "my_sequence");
virtual task body();
child_item = child_seq_item::type_id::create("child_item");
`uvm_do(child_item)
child_item.print();
And I execute the sequence in my test class.
class mem_wr_rd_test extends mem_model_base_test;
`uvm_component_utils(mem_wr_rd_test)
mem_sequence seq;
function new(string name = "mem_wr_rd_test",uvm_component parent=null);
super.new(name,parent);
endfunction : new
seq = mem_sequence::type_id::create("seq");
endfunction : build_phase
phase.raise_objection(this);
seq.start(env.mem_agnt.sequencer);
phase.drop_objection(this);
//set a drain-time for the environment if desired
phase.phase_done.set_drain_time(this, 50);
endtask : run_phase
class my_test extends mem_wr_rd_test;
`uvm_component_utils(my_test)
my_sequence my_seq;
function new(string name = "my_test",uvm_component parent=null);
endfunction : new
// Create the sequence
my_seq = my_sequence::type_id::create("my_seq");
my_seq.start(env.mem_agnt.sequencer);
endtask : run_phase
This is the Driver.
class mem_driver extends uvm_driver #(mem_seq_item);
child_seq_item csi;
virtual mem_if vif;
`uvm_component_utils(mem_driver)
endfunction : new
if(!uvm_config_db#(virtual mem_if)::get(this, "", "vif", vif))
`uvm_fatal("NO_VIF",{"virtual interface must be set for: ",get_full_name(),".vif"});
csi = child_seq_item::type_id::create("csi", this);
endfunction: build_phase
drive(req);
`DRIV_IF.addr <= req.addr;
`DRIV_IF.addr <= req.B; //<======!!!! HERE, I can't get the item B.!!!!!!!
`DRIV_IF.addr <= csi.B;
seq_item_port.item_done();
endtask : run_phase
virtual task drive(input mem_seq_item trans );
`DRIV_IF.wr_en <= 0;
`DRIV_IF.rd_en <= 0;
@(posedge vif.DRIVER.clk);
`DRIV_IF.addr <= trans.A; //<======!!!! HERE, I can't get the item A.!!!!!!!
if(req.wr_en) begin // write operation
`DRIV_IF.wr_en <= req.wr_en;
`DRIV_IF.wdata <= req.wdata;
else if(req.rd_en) begin //read operation
