Factor override does not occur. Need to know why? pls see code below
class mytran extends uvm_sequence_item;
  `uvm_object_utils(mytran)  //register in the factory
  string msg ;
  rand int a ;
  rand int b ;
  int sum ;
  constraint a_c { a inside {[0:10]};}
  constraint b_c { b inside {[0:10]};}
  function new (string name = "mytran");
    super.new(name) ;
  virtual function void print () ;
    `uvm_info("in item)(in parent)", get_full_name(), UVM_LOW);
    `uvm_info("in item)(in parent: type name)", get_type_name(), UVM_LOW);
class mytran_new extends mytran;
  `uvm_object_utils(mytran_new)  //register in the factory
  rand int c ;
  rand int d ;
  function new (string name = "mytran_new");
    super.new(name) ;
class adder_model_test extends uvm_test;
  `uvm_component_utils(adder_model_test)
  adder_model_env env;
  mytran_sequence  seq;
  function new(string name = "adder_model_test",uvm_component parent=null);
    super.new(name,parent);
  endfunction : new
    //factory code below this line:
    set_type_override_by_type(mytran::get_type(), mytran_new::get_type(), 1'b1) ;
    env = adder_model_env::type_id::create("env", this);
    seq = mytran_sequence::type_id::create("seq", this);
  endfunction : build_phase
          phase.raise_objection(this);
    `uvm_info($sformatf("%0d", $time), "connect the sequence to the sequencer before", UVM_LOW)
    `uvm_info(get_type_name(), "connect the sequence to the sequencer before", UVM_LOW)
          seq.p_sequencer = env.adder_agnt.sequencer ;
    if(seq.p_sequencer == null) begin
      `uvm_fatal("The sequencer is null", "") ;
          seq.start(env.adder_agnt.sequencer);
    `uvm_info(get_full_name(), "connect the sequence to the sequencer later", UVM_LOW)
          phase.drop_objection(this);
  endtask : run_phase
endclass : adder_model_test
In reply to samerh:
Please use code tags making your code easier to read. I have added them for you.
You never showed creation of a mytran class to be overridden, but the call to set_type_override_by_type() would only override the mytran class created in the adder_model_test component. You probably want to do a global type override.
    uvm_factory::get().set_type_override_by_type(mytran::get_type(), mytran_new::get_type(), 1'b1) ;
I tried your fix and it did not override. Here is the reset of the code:
  string msg ;
//class mytran # (parameter type data = int) ;
  rand int a ;
  rand int b ;
  int sum ;
    super.new(name) ;
  rand int c ;
  rand int d ;
    super.new(name) ;
class adder_sequencer extends uvm_sequencer #(mytran);
  `uvm_component_utils(adder_sequencer)
  //constructor
class mytran_sequence extends uvm_sequence #(mytran, mytran);
  `uvm_object_utils(mytran_sequence)
  //`uvm_declare_p_sequencer(adder_sequencer)
  //The above macro exeuctes this function:
  //`define uvm_declare_p_sequencer(SEQUENCER) \
  adder_sequencer  p_sequencer;
  virtual function void m_set_p_sequencer();
    super.m_set_p_sequencer();
    if( !$cast(p_sequencer, m_sequencer))
        `uvm_fatal("DCLPSQ", $sformatf("%m %s Error casting p_sequencer, please verify that this sequence/sequence item is intended to execute on this type of sequencer", get_full_name()))
  // adder_sequencer ;
  rand mytran mytran0 ;
  mytran rsp ;
    function new (string name = "mytran_sequence") ;
      mytran0 = mytran::type_id::create("tran-0") ;
      rsp = new ; //already defined so there is no need for this line.
  function void pr ;
    $display("(from sequence): value of a = %d, b = %d", mytran0.a, mytran0.b) ;
    //$display("(from sequence): value of c = %d, d = %d", mytran0.c, mytran0.d) ;
    mytran0.print() ;
  virtual task body ( ) ; //runtime task
    for (int i = 0 ; i < 10; i++) begin
      if(mytran0.randomize()) begin
        pr() ;
        wait_for_grant();
        send_request(mytran0);
        wait_for_item_done();
        get_response(rsp) ; //recieve a response from the sequencer
        `uvm_info("(in sequence): here is the response message", rsp.msg, UVM_LOW);
