Hello ,
i am seeing below error in my uvm environment , please guide me to resolve the issue .
1, below error pointing in driver file when calling get function of container . we are using set function in container also. is it required to set any where(means in top file), if its required how to set and where to set.
2. in driver he is getting the virtual interface using uvm_config_object but i am not able to set virtual interface using uvm_config_object set , i tried with setting uvm_config_db, but still its giving the below error. is it possible to set virtual interface using uvm_config_object set method in top. if its possible how to set or how to pass virtual interface uvm_config_object
ERROR:
Error-[NOA] Null object access
The object at dereference depth 0 is being used before it was
constructed/allocated.
Please make sure that the object is allocated before using it.
top file:
uvm_config_db#(virtual JtagBfmIntf)::set(null, ".*" , "V_JTAGBFM_PIN_IF", dfx_if);
driver file code:
super.connect_phase (phase);
$swrite (msg, "Getting the virtual JtagBfmPinIf interface");
`uvm_info (get_full_name(), msg, UVM_MEDIUM);
// Assigning virtual interface
if(uvm_config_object::get(this, "","V_JTAGBFM_PIN_IF", temp))
if(!$cast(vif_container, temp))
`uvm_fatal(get_full_name(),"Agent fail to connect to TI. Search for string << active agent exists at this hierarchy >> to get the list of all active agents in your SoC");
PinIf = vif_container.get_v_if ();
container class file:
// Set Virtual Interface Function
`ifdef CHASSIS_JTAGBFM_USE_PARAMETERIZED_CLASS
virtual function void set_v_if (T virt_if);
`else
virtual function void set_v_if (virtual JtagBfmIntf virt_if);
`endif
v_if = virt_if;
endfunction : set_v_if
// Get Virtual Interface Function
virtual function T get_v_if ();
`else
virtual function virtual JtagBfmIntf get_v_if ();
`endif
return (v_if);
endfunction : get_v_if
// Clone Function
virtual function uvm_object clone ();
JtagBfmIfContainer #(T) temp = new this;
`else
JtagBfmIfContainer temp = new this;
`endif
clone = temp; //return(temp);
endfunction : clone
In reply to Abhilash c h:
Why you are using get on the config_object? You should make a get on the config_db in your driver.
BTW use the uvm reporting Marcos instead of $swrit.
[/quote]
1.i can get using config_db. but in this case i can’t able to container class implemented function
2.actually this is standalone vip ,i am integrating into my subsystem environment.in this vip they are getting virtual interface like below
if(uvm_config_object::get(this, “”,“V_JTAGBFM_PIN_IF”, temp))
they declared temp as uvm_object temp; and casting into vif_container. they declared vif_container as handle for vif_container class. when calling container function i am facing above error.
PinIf = vif_container.get_v_if ();// here its pointing error.
- how to set or handle config_object for above uvm_config_object::get function using virtual interface
Again, you are mixing the container approach with the config_db.
Could you please show the whole container class code.
class JtagBfmIfContainer #(type T = int) extends uvm_object;
`else
class JtagBfmIfContainer extends uvm_object;
`endif
`uvm_object_utils(JtagBfmIfContainer)
// The virtual interface to drive DUT signals
protected T v_if;
`else
protected virtual JtagBfmIntf v_if;
`endif
// Constructor Function
function new (string name="JtagBfmIfContainer");
super.new (name);
endfunction : new
`else
`endif
v_if = virt_if;
`else
`endif
return (v_if);
// Clone Function
`else
`endif
endfunction : clone
endclass : JtagBfmIfContainer
The UVM base class librry does not know a class ‘uvm_container’. In your implementation you are using a conffiguration object which is defined by your own.
A configuration object and the configuration_db are completely different things. The configuration opbject is a class which is used to configure any uvm_component or tarnsient object like seq_items ot uvm_sequemces.
The config_db is a data base where we can store any type of objects. These can be set in a component and they cam be retrieved in any other component across the hierarchy. This is a very powerful approch. We use this approach to perfrom the connections through the vortual interface, by passing it to the config_db from the toplevel module (ste) and retrieving it in any of the transactors like uvm_driver or uvm_monitor.
We can also add the virtual interface to a configuration object and passing this object to the config_db and retrieving this from there.
This is the common and recommended approach.
You are mixing both approaches and this is your problem.
Additionally in your JtagBfmIfContainer you are things wrong, because you are differentiating between a parameterized version ad a version without parameter. The parameterized version needs a differnt registration macro than the version without a parameter.
Try to clean-up your code and follow the recommendations.
For details see the chapetr ‘DUT-Testbench Connections’ in the UVM-Cookbook (UVM | Verification Academy).
