I have a reactive sequence that waits for an event for it to send a transaction. Once the transaction is sent it again has to wait for the event to occur. So basically I have this logic inside a forever loop of my sequence. This results in the simulation never ending since the forever-loop is never exited. What are the ways in which I can exit such a sequence?
Here is my code -
task body ();
wait (p_sequencer.event_que.size() > 0); //This is the event for which it waits. This queue is populated by the sequencer
p_sequencer.event_que.pop_front(); //Clearing it to make sure the size of the queue is 0 so as to 'wait' again
trans.randomize(); //randomize fields of transaction
start_item(trans);
finish_item(trans);
This sequence itself is started from the run_phase of the test under fork-join (there are sequences running on other interfaces too)
you need to drop the objections to stop the simulation.
virtual task main_phase(uvm_phase phase);
super.main_phase(phase);
phase.raise_objection(this, "raise objection"); //raise objection
/* //infinite sequence
seq1 = my_sequence_1::type_id::create("seq1");
seq1.randomize();
seq1.start(env.agt.sequencer);
join_none
//wait for the event/end of other sequence after that you want to stop the simulation
phase.drop_objection(this, "drop objection"); //drop objection
endtask : main_phase
//example 2, if you want to stop the simulation after any one of the sequence is finished
begin //T1
seq1.randomize();
begin //T2
/* seq2 */
begin //T3
/* seq3 */
begin //Tn
/* seqn */
join_any
Here is my code -
task body ();
start_item(trans);
finish_item(trans);
What you are doing is a bad coding style. The only way to stop this sequence is to kill it and this also bad for the execution.
The body task of a sequence does never contain a forever loop!
In reply to Rahulkumar:
Thanks Rahulkumar. I will try with fork-join_any. I think that might work
The fork/join_any will not stop the executung unless you have at least 1 sequence without a forever loop. What Rahulkumar is recommending is useless if you do not need such a sequence execution structure.
Thanks chr_sue. What is the recommended way to handle such sequences? How can I be in the sequence waiting for an event without a forever loop?
It is recommended to recode your body tasks and replace all forever loops with loops running a well defined number of loops. The number of the loops can be controlled from the test by setting test-specific numbers of loops.
In reply to tpan:
I have recommended two different use cases. Which one to use depended on requirement and constraint.
I have clearly mentioned to use fork/join_any “if you want to stop the simulation after any one of the sequence is finished”
