Hi All,
I found a code below-
`uvm_component_utils(my_test)
phase.raise_objection(this);
my_seq.start(m_sequencer);
/// Set a drain time for the Test
phase.phase_done.set_drain_time(this, 20ns);
phase.drop_objection(this);
endtask: run_phase
endclass: my_test
How the set_drain_time is different from the regular delay? What if I just replace the line
with
#20; //assuming 1cycle is 1ns
