how to run the multiple test cases for single dut and test bench using linux and questasim.
i have written the testbench using uvm
In reply to vinayks:
Are you just needing to run a few tests for yourself, one after the other? Or do you need a solution that can run many tests in parallel on a compute farm?
If you’re just serially running jobs on your own machine, some simple shell scripting will suffice. If you want to submit a regression to a compute farm, you’ll need cluster management software, along with a lot of scripting.
You either need to build your own scripts, or you need to find a vendor that can provide or build a solution for you.
In reply to warnerrs:
Hi warners,
other than building scripts is there any alternative methods to run all my test cases serially??
Scripting is how it’s done. The alternatives are just too painful, and not scalable. If your needs are simple, like say for a tiny academic project, then something like the following simple bash script can get you a long ways. You’ll need to replace vendor_specific_sim_command and vendor_specific_seed_switch with whatever is appropriate for your tools.
If you want this to be a complete solution, you’ll also need to add some log parsing to evaluate test results, and report a tally of passing/failing tests at the end.
#!/bin/bash
# Define Helper Functions
tool_cmd() {
local t="$1"; shift # test class name
local s="$1"; shift # seed to use
# ( set -x; command ) will cause the command to print before running the command
( set -x; vendor_specific_sim_command +UVM_TESTNAME=$t -vendor_specific_seed_switch=$s $@ )
# join input array together with -'s
join() { local IFS="-"; echo "$*"; }
# Make a directory to run the test, change to that directory and run the test; send the output to stdout and sim.log
run_test() {
local tdir=$( join $t SEED $s $@ )
mkdir $tdir && pushd $tdir && tool_cmd $t $s $@ 2>&1 | tee sim.log
popd
rand_test() {
local nseeds="$1"; shift # Number of unique random seeds to run test with
# Generate nseeds unique random seeds between 1 and 10000, thanks interwebs: https://www.unix.com/unix-for-dummies-questions-and-answers/20150-random-numbers-without-repetition.html
local seeds=$(for i in {1..10000}; do echo $RANDOM $i; done|sort |cut -d" " -f2|head -$nseeds)
for s in $seeds; do
run_test $t $s $@
done
# Run Tests
# Run test1 with 5 unique random seeds, passing "+plus_arg" to the simulation command
rand_test 5 test1 +plus_args
# Run test2 once with a fixed seed=10
run_test test2 10
Also you can use Makefile for such purposes.
Main benefit of using Makefile, that you would not need to recompile previously compiled modules.
