Hi,I was trying to verify read-write functionality in a memory.
unable to understand what this error is:
Error-[XMRE] Cross-module reference resolution error
testbench.sv, 194
Error found while trying to resolve cross-module reference.
token ‘cgf’. Originating package ‘$unit’.
Source info: if (cgf.is_active == 1) begin
this.driver = sfr_driver::type_id::create(“driver” …
code:
class sfr_agent extends uvm_agent;
`uvm_component_utils(sfr_agent)
function new(string name = "sfr_agent", uvm_component parent = null);
super.new(name,parent);
uvm_analysis_port #(sfr_seq_item) ap;
sfr_seqr sequencer;
sfr_driver driver;
sfr_monitor monitor;
sfr_config_object cfg;
if(cfg == null) begin
if(!uvm_config_db #(sfr_config_object)::get(this,"","SFR_CFG",cfg))
`uvm_error("BUILD_PHASE", "Unable to find sfr agent config object in uvm_config_db");
ap = new("ap",this);
monitor = sfr_monitor::type_id::create("monitor",this);
// error in this line
**if (cgf.is_active == 1) begin
driver = sfr_driver::type_id::create("driver",this);
sequencer = sfr_seqr::type_id::create("sequencer",this);
end**
monitor.SFR = cfg.SFR;
monitor.ap.connect(ap);
if(cfg.is_active == 1) begin
driver.SFR = cfg.SFR;
