Hello All !
Have a scenario where in I try to launch a rsp sequence based on the request monitored and sent to the scoreboard.
a. Have a simple uvm_event_pool and uvm_event defined inside the uvm_scoreboard as given below
class aloha extends uvm_scoreboard;
uvm_event_pool ev_pool;
uvm_event evt;
task run_phase();
ev_pool = ev_pool.get_global_pool();
evt = ev_pool.get("evt"); // Get the below error for the following line.
evt.trigger("lnc_rsp_seq");
b. And have a similar event setup in the sequence to receive an event from the scoreboard with the data. So based on the string, was planning to launch a required sequence. But I keep getting this below error.
Error :
Illegal class assignment
-I-: …
-I-: “this.evt = this.evt_pool.get(“evt”);”
-I-: Expression ‘this.evt_pool.get(“evt”)’ on rhs is not a class or a
-I-: compatible class and hence cannot be assigned to a class handle on lhs.
-I-: Please make sure that the lhs and rhs expressions are compatible.
Can anyone explain what the error could be or what is causing this error ? Is the uvm_event placement inside the scoreboard erroneous ?
