Error : null object access
class master_drv extends uvm_driver #(master_txn);
  `uvm_component_utils(master_drv)
  master_agt_config m_cfgh;
  virtual uart_inf vif;
  master_txn xtnh;
    logic   [31:0]      divisor;
    time               	clk_prd;
    real 			    clk_frq;
    reg     [31:0]      cnt;
   	time 				clk_rise_edge ;
    logic bclk;
  //////////////////new_constructor//////////////////////////////
  function new(string name="master_drv",uvm_component parent);
    super.new(name,parent);
  /////////////////////////////build_phase//////////////////////////////
  virtual function void buid_phase(uvm_phase phase);
    if(!uvm_config_db#(master_agt_config)::get(this,"","master_agt_config",m_cfgh))
    `uvm_fatal("MASTER","cannot get the master config from config_db");
   xtnh=master_txn::type_id::create("xtnh");
  ////////////////////////////connect_phase/////////////////////////
    super.connect_phase(phase);
   vif=m_cfgh.vif;
  ////////////////////run_phase/////////////////////////////
    @(posedge vif.g_clk)
     vif.g_rst<=0;
       vif.g_rst<=1;
   forever
         uart_bclk(req);
        seq_item_port.item_done();
  task uart_bclk(master_txn xtnh);
   forever
      clk_rise_edge = $time;
      $display( "time = %t ; clk_rise_edge = %t",$time, clk_rise_edge);
      @(posedge vif.g_clk) begin
     	 clk_prd = $time -  clk_rise_edge;
   		 clk_frq = 1e9 / (clk_prd );
    $display( "frequency = %g ",clk_frq);
    divisor = clk_frq / (xtnh.baud_rate);
    $display( "divisor= %d ",divisor);
    @ (posedge vif.g_clk or posedge vif.g_rst)
      if(vif.g_rst) begin
        cnt  <= 32'd0;
      	bclk <= 1'b0;
      else if(cnt >= divisor) begin
        bclk <= 1'b1;
      	cnt  <= 32'd0;
      else begin
        cnt <= cnt + 1'b1;
      	bclk<= 1'b0;
Error-[NOA] Null object access
master_drv.sv, 38
The object at dereference depth 1 is being used before it was
constructed/allocated.
Please make sure that the object is allocated before using it.
line no 38 : vif = mcfgh.vif;
even though i have constructed config am getting null object access.
may i know what is wrong with the code
In reply to ranju.ranjitha555@gmail.com:
Success when calling uvm_config_db::get() indicates that the requested type/id exists in the uvm_config_db. You can still pass a null value, which is what I’m guessing that you did when you called set(). Verify that m_cfgh is valid when you call set().
