hi all,
i have tried testbench for counter in UVM. I found above errors when i compiled on questasim 10.c so can anyone help me out.
error: Macro 'uvm_object_utils is undefined
near “(”: syntax error, Unexpected ‘(’ , expecting function or task -
error: near “#”: syntax error, unexpected ‘#’
//code starts here
module Counter(clk,reset,data);
input wire clk,reset;
output reg [3:0] data;
always @ (posedge clk)
if(reset)
data<=0;
else
data<=data+1;
interface Bus_if;
wire clk;
wire reset;
reg [3:0] data;
endinterface
`include "uvm_macros.svh"
module top();
//generate the clock
reg clk = 0;
forever #5 clk = ~clk;
//interface instance
Bus_if Bus_if1();
// Dut instance
Counter Counter1(Bus_if1.clk,Bus_if1.reset,Bus_if1.data);
//set virtual interface
uvm_config_db#(virtual Bus_if)::set(null,"*","Bus_if1",Bus_if1);
run_test();
//testbench starts here
class counter_trans extends uvm_sequence_item;
rand bit clk;
rand bit reset;
rand bit data;
function new(string name="");
super.new(name) ;
`uvm_object_utils_begin(counter_trans)
`uvm_field_int ( clk, UVM_ALL_ON )
`uvm_field_int ( reset,UVM_ALL_ON )
`uvm_field_int ( data, UVM_ALL_ON )
`uvm_object_utils_end
//counter sequence definition is here
class count_seq extends uvm_sequence#(counter_trans);
`uvm_object_utils(count_seq)
virtual Bus_if Bus_if1;
super.new(name) ;
void'(uvm_config_db#(virtual Bus_if)::get(this,"*","Bus_if1",Bus_if1));
if(!uvm_config_db#(virtual Bus_if)::get(this,"* ","Bus_if1",Bus_if1)) begin
`uvm_error("","uvm_config_db::get failed in driver");
task body ();
counter_trans req;
req=counter_trans::type_id::create("req",this);
if(Bus_if1.clk) begin
start_item( req.randomize() );
finish_item(req); // this function used to send transaction items to driver
// req.start(sqr);
else if (!req.randomize()) begin
`uvm_error("MY_SEQUENCE", "Randomize failed.");
//sequencer defination
class counter_sequencer extends uvm_sequencer # (counter_trans);
`uvm_component_utils(counter_sequencer)
super.new(name) ;
class driver extends uvm_driver # (counter_trans);
`uvm_component_utils(driver)
function new(string name,uvm_component_parent="null");
super.new(name,null);
// req = sequence_gen::type_id::create("req",this);
counter_trans req;
// gets the sequence item from the sequence_gen
if(Bus_if1.clk<=req.clk)
Bus_if1.reset <=req.reset;
Bus_if1.data <= req.data;
seq_item_port.item_done();
join_none
class monitor extends uvm_monitor;
`uvm_component_utils(monitor)
uvm_analysis_port # (counter_trans) ap_objseq;
function new(string name, uvm_component_parent="null");
super.new(name, null);
ap_objseq = new(.name("ap_objseq"),.parent(this));
task run_phase( uvm_phase phase);
//sequence_gen req;
counter_trans req;
@ Bus_if1.clk;
req.reset = Bus_if1.reset;
req.data = Bus_if1.data;
ap_objseq.write(req);
class coverage extends uvm_subscriber # (counter_trans);
`uvm_component_utils(coverage)
counter_trans req;
covergroup count_cov;
coverpoint req.clk;
coverpoint req.reset;
coverpoint req.data;
endgroup
count_cov = new();
function void write(counter_trans cov_tx);
req = cov_tx;
req.clk = cov_tx.clk;
req.reset = cov_tx.reset;
req.data = cov_tx.data;
count_cov.sample();
typedef class scoreboard;
class counter_subscriber extends uvm_subscriber # (counter_trans);
`uvm_component_utils(counter_subscriber)
counter_trans req;
function new (string name, uvm_component_parent="null");
function void write(counter_trans sb_tx);
req = sb_tx;
req.clk = sb_tx.clk;
req.reset = sb_tx.reset;
req.data = sb_tx.data;
class scoreboard extends uvm_scoreboard;
`uvm_component_utils(scoreboard)
scoreboard sb;
local counter_subscriber counter_sub;
rand bit store;
// ap_objseq = sequence_gen::type_id::create("ap_objseq",this);
counter_sub=counter_subscriber::type_id::create("counter_sub",this);
super.connect_phase(phase);
ap_objseq.connect( counter_sub.analysis_export );
task run_phase();
// if(Bus_if1.clk) begin
// if(!Bus_if1.reset) begin
if(sb.clk) begin
if(!sb.reset) begin
sb.store = sb.store+1;
else begin
sb.store = 0;
if(sb.store==req.data) begin
`uvm_info("","test has been passed","UVM_LOW");
class agent extends uvm_agent;
`uvm_component_utils(agent)
// virtual Bus_if Bus_if1;
counter_sequencer sqr;
driver drv;
monitor mtr;
scoreboard sb;
coverage cov;
super.buid_phase(phase);
drv = driver::type_id::create("drv",this);
mtr = monitor::type_id::create("mtr",this);
sb = scoreboard::type_id::create("sb",this);
cov = coverage::type_id::create("cov",this);
sqr = counter_sequencer::type_id::create("sqr",this);
/*if(!uvm_config_db#(virtual Bus_if)::get(this,"","Bus_if1",Bus_if1))
`uvm_fatal("In agent","virtual interface not got successful");
/* uvm_config_db # (virtual Bus_if)::set(this,"monitor","Bus_if1",Bus_if1);
uvm_config_db # (virtual Bus_if)::set(this,"driver","Bus_if1",Bus_if1);
uvm_config_db # (virtual Bus_if)::set(this,"coverage","Bus_if1",Bus_if1);
drv.seq_item_port.connect(sqr.seq_item_export);
mtr.ap_objseq.connect(ap_objseq);
// environment defination
class environment extends uvm_env;
`uvm_component_utils(environment)
agent agt;
coverage cov;
scoreboard sb;
counter_subscriber count_sub;
super.new(name,parent);
agt = agent::type_id::create("agt",this);
// seq_env = sequence_gen :: type_id::create("seq_env",this);
cov = coverage :: type_id::create("cov",this);
sb = scoreboard :: type_id::create("sb",this);
count_sub=counter_subscriber::type_id::create("count_sub",this);
agt.ap_objseq.connect(cov.analysis_export);
agt.ap_objseq.connect(sb.analysis_export);
agt.ap_objseq.connect(count_sub.analysis_export);
class test_count extends uvm_test;
`uvm_component_utils(test_count)
environment env;
env = environment::type_id::create("env",this);
// task run_test(uvm_phase phase);
counter_trans req;
phase.raise_objection(this);
req.start(env.agt.sqr);
#10
phase.drop_objection(this);
