Hi
I want to enable the file Path names in my log.
I commented the define “UVM_REPORT_DISABLE_FILE_lINE” and “UVM_REPORT_DISABLE_FILE”.
Still i could not able to see file path names in my log.
Can anybody please help
Is there any other switches?
Ali
In reply to naaj_ila:
I’m not sure what you are looking for, because using the macro `uvm_info is displaying the complete file names (including path) to your logfile. Maybe your simulator is suppressing this.
What is your simulator?
If we add the define “UVM_REPORT_DISABLE_FILE”, it will suppress the file pathnames
It was added in some file.But i commented that , still it is suppressign the filepath
For easy debugging , i need this file path.
Simulator :VCS
You don’t have to set any defines.
Here is an example from my log-file:
UVM_INFO …/tb/apb/sv/apb_seq_lib.sv(97) @ 9000: uvm_test_top.env.apb_env_i.agent.sequencer@@apb_seq [apb_default_seq] default sequence completed
UVM_INFO …/tb/example_top/sv/example_top_seq_lib.sv(106) @ 9000: reporter@@vseq [example_top_default_seq] spi sequence starting
UVM_INFO …/tb/spi/sv/spi_seq_lib.sv(85) @ 9000: uvm_test_top.env.spi_env_i.agent.sequencer@@spi_seq [spi_default_seq] default sequence starting
UVM_INFO …/tb/spi/sv/spi_seq_lib.sv(54) @ 9000: uvm_test_top.env.spi_env_i.agent.sequencer@@spi_seq [spi_default_seq] spi_base_seq
UVM_INFO …/tb/apb/sv/apb_monitor.sv(74) @ 10000: uvm_test_top.env.apb_env_i.agent.monitor [apb_monitor] write trans to ap
Is that something you would like to see?
I have no VCS license and cannot check if we get the same in the VCS log-file.
It was added in some file.But i commented that , still it is suppressing the filepath
You cannot comment out a
`define that has been defined earlier. You need to use
`undef UVM_REPORT_DISABLE_FILE
Also, you need to make sure you are using uvm_info or passing
FILE and `LINE to uvm_report_info().
Hi Dave,
I tried with Commenting “UVM_REPORT_DISABLE_FILE” -->NOT WORKED
`undef “UVM_REPORT_DISABLE_FILE” → NOT WORKED
Added this define on the top of testcase-->NOT WORKED
define uvm_info(ID,MSG,VERBOSITY) \ begin \ if (uvm_report_enabled(VERBOSITY,UVM_INFO,ID)) \ uvm_report_info (ID, MSG, VERBOSITY,
FILE, __LINE__); \ end Replaced
uvm_file and uvm_line with
FILE and `LINE respectively
Added this define on the top of testcase–>WORKED
define uvm_info(ID,MSG,VERBOSITY) \ begin \ if (uvm_report_enabled(VERBOSITY,UVM_INFO,ID)) \ begin\ $display(
FILE,__LINE__);\ uvm_report_info (ID, MSG, VERBOSITY,
FILE, __LINE__); \ end\ end Replaced
FILE and `LINE respectively and added $display .Worked with $display.
I am not sure why uvm_info __FILE__ and
LINE is not working
Any guess?
I suggest you contact your vendor for support.
