DUT output coming as XX (unknown values)
Hi All,
Here is the small example to drive some values from driver and display the same in DUT. But output is coming as XX, may I know where I went wrong?
//DUT CODE
module dut(dut_if dif);
always @(posedge dif.clock)
    `uvm_info("", $sformatf("DUT Received cmd=%h H, data=%h H, addr=%h H",
              dif.cmd, dif.data, dif.address ), UVM_MEDIUM )
//INTERFACE CODE
interface dut_if;
logic clock, reset;
logic cmd;
logic [7:0] data;
logic [7:0] address;
endinterface
//ENVIRONMENT
class my_env extends uvm_env;
`uvm_component_utils(my_env)
endfunction: new
endfunction: build_phase
endclass: my_env
//TEST
`uvm_component_utils(my_test)
my_env my_env_h;
endfunction: new
super.build_phase(phase);;
my_env_h = my_env::type_id::create("my_env_h", this);
phase.raise_objection(this);
`uvm_info("TOP TEST", "HELLO_BEGINS", UVM_MEDIUM);
#80;
`uvm_info("TOP TEST", "HELLO_ENDS", UVM_MEDIUM);
phase.drop_objection(this);
endclass: my_test
//TOP CODE
module top;
import my_pkg::*;
dut_if dut_if1 ();
dut dut1 (.dif(dut_if1) );
dut_if1.clock = 0;
forever #5 dut_if1.clock = ~dut_if1.clock;
uvm_config_db #(virtual dut_if)::set( null, "*", "dut_if", dut_if1 );
uvm_top.finish_on_completion = 1;
run_test("my_test");
//DRIVER
class my_driver extends uvm_driver;
`uvm_component_utils(my_driver)
virtual dut_if dut_vi;
if (! uvm_config_db #(virtual dut_if)::get (this, "", "dut_if", dut_vi) )
    `uvm_error("", "uvm_config_db get failed")
  forever
@(posedge dut_vi.clock);
dut_vi.cmd      <= $urandom;
dut_vi.data     <= $urandom;
dut_vi.address  <= $urandom;
output
UVM_INFO my_test.svh(19) @ 0: uvm_test_top [TOP TEST] HELLO_BEGINS
UVM_INFO dut.sv(10) @ 5: reporter DUT Received cmd=x H, data=xx H, addr=xx H
UVM_INFO dut.sv(10) @ 15: reporter DUT Received cmd=x H, data=xx H, addr=xx H
These are the possible methods tried, but I got the same results.
  1. Replaced <= operator with = operator in driver. Like;
    dut_vi.cmd = $urandom;
  2. Replacing $sformatf in DUT with $psprintf.
  3. Changing data type in interface from logic to bit.
In reply to Mahesh K:
There is no instance of your Driver in the env!
Lets assume, I will create a instance of driver in environment like;
my_driver obj_driver;
Then do I need to use again “uvm_config_db… get()” in environment?
you have to create a object of a driver in the environment/test for the Driver, and
my_driver obj_driver; and then the create menthod for the same to create the handle and actual memory space of the object.
doing uvmuvm_config_db… get() , please see you are getting the Virtual interface , and you generally use that in the driver , why again you want to get it in the env, no need!!!
just add the driver object and create the obeject
does not create an object. It defines only a reference.
You have to call the type_id::create method of the factory.
This creates your object. In this object you have to call the get method of uvm_config_db to get the virtual Interface.
Hi Thank you all, got expected output.
Please forgive me for late response.
Here is the output;
UVM_INFO dut.sv(10) @ 15: reporter DUT Received cmd=0 H, data=da H, addr=c3 H
UVM_INFO dut.sv(10) @ 25: reporter DUT Received cmd=1 H, data=c4 H, addr=44 H
UVM_INFO dut.sv(10) @ 35: reporter DUT Received cmd=1 H, data=be H, addr=25 H
UVM_INFO dut.sv(10) @ 45: reporter DUT Received cmd=0 H, data=b7 H, addr=73 H
UVM_INFO dut.sv(10) @ 55: reporter DUT Received cmd=0 H, data=64 H, addr=4b H
UVM_INFO dut.sv(10) @ 65: reporter DUT Received cmd=1 H, data=08 H, addr=85 H
UVM_INFO dut.sv(10) @ 75: reporter DUT Received cmd=1 H, data=ae H, addr=e5 H
UVM_INFO my_test.svh(21) @ 80: uvm_test_top [TOP TEST] HELLO_ENDS
