Driver seeing unknown values after virtual sequencer is implemented
I am trying implement virtual sequencer by having multiple sequences within a single sequence. I only have one sequencer but still need to reuse the sequences for a complex scenario. I am seeing xxx values at the driver while transaction values are proper at the sequencer. I feel the I have made the proper connections. Following is my code :
program dut_test();
import dut_pkg_uvm::*;
`include "uvm_macros.svh"
class dut_level0_preset_lock extends dut_test_base;
	`uvm_component_utils(dut_level0_preset_lock)
	dut_preset_lock_seq dut_preset_seq;
	function new (string name = "dut_level0_preset_lock", uvm_component parent=null);
	// End of Elaboration Phase
	function void end_of_elaboration_phase(uvm_phase phase);
		super.end_of_elaboration_phase(phase);
		dut_preset_seq = dut_preset_lock_seq::type_id::create("dut_preset_seq");
		dut_preset_seq.m_sequencer = m_env.m_agent.m_sequencer;
		phase.raise_objection(this, "Starting UVM Preset lock test");
		`uvm_info("TEST", "START OF TEST", UVM_LOW)
		`uvm_info("TEST", "START OF PRESET SEQUENCE", UVM_LOW)
		dut_preset_seq.start(null);//m_env.m_agent.m_sequencer);
		`uvm_info("TEST", "PASS", UVM_LOW)
		phase.drop_objection(this, "UVM Preset lock test finished");
	endtask : run_phase
	endclass : dut_level0_preset_lock
		run_test("dut_level0_preset_lock");
	endprogram
	class Seq_hard_reset extends uvm_sequence #(dut_txn);
	function new(string name="");
	`uvm_object_utils(Seq_hard_reset)
	virtual task body;
		dut_txn  req = dut_txn::type_id::create("req");
		`uvm_info(get_type_name(),"Starting reset request", UVM_MEDIUM);
		start_item(req);
		req.reset <= 1'b1;
		finish_item(req);
		`uvm_info(get_type_name(),"Done with hard reset request", UVM_MEDIUM);
	endtask : body
class Seq_enable_clk_gen  extends uvm_sequence #(dut_txn);
	`uvm_object_utils(Seq_enable_clk_gen)
	function new(string name="Seq_enable_clk_gen");
	dut_txn req;
	virtual task body;
		`uvm_info(get_type_name(),"Starting clk generation request", UVM_MEDIUM);
		start_item(req);
		req.reset <= 1'b0;
		req.clk_gen <= 1'b1;
		finish_item(req);
		`uvm_info(get_type_name(),"Done with clk genereation request", UVM_MEDIUM);
		`uvm_info("seq_body_clk_en", req.convert2string(), UVM_LOW);
	endtask : body
class preset_lock_base_seq  extends uvm_sequence #(dut_txn);
	//PSET Mode
	rand bit [4:0] pset_mode;
	dut_txn req;
	function new(string name="preset_lock_base_seq");
	`uvm_object_utils(preset_lock_base_seq)
	virtual task body;
		`uvm_info(get_type_name(),"Starting preset_base request", UVM_MEDIUM);
		start_item(req);
		req.reset <= 1'b0;
		req.valid <= 1'b1;
		pset_mode <= 5'd2;
		req.udb <= {1'b0,pset_mode};
		req.enable <= 1'b1;
		req.parasel <= 1'b1;
		req.delay <= 15;
		finish_item(req);
		`uvm_info(get_type_name(),"Done with preset base request", UVM_MEDIUM);
		`uvm_info("seq_body_preset_base", req.convert2string(), UVM_LOW);
	endtask : body
class dut_preset_lock_seq extends uvm_sequence #(dut_txn);
	`uvm_object_utils(dut_preset_lock_seq)
	Seq_hard_reset reset_seq;
	Seq_enable_clk_gen en_clk_gen_seq;
	preset_lock_base_seq preset_base_seq;
	dut_sequencer  m_sequencer;
	function new(string name = "dut_preset_lock_seq");
	task body;
		reset_seq = Seq_hard_reset::type_id::create("reset_seq");
		en_clk_gen_seq = Seq_enable_clk_gen :: type_id::create("en_clk_gen_seq");
		preset_base_seq = preset_lock_base_seq :: type_id::create("preset_base_seq");
			//reset the dut
			reset_seq.start(m_sequencer,this);
			#2ns;
			//enable_clk_gen
			en_clk_gen_seq.start(m_sequencer,this);
			#2ns;
			preset_base_seq.start(m_sequencer,this);
			#6ns;
	endtask: body
endclass:dut_preset_lock_seq
In reply to Varunshivashankar:
Code is not formatted well (Look at tags while posting) making it hard to read/follow. Also looks like the driver code is not shown. My guess - you are using NBA for class variables - not a good idea (Believe it was illegal, now allowed in latest LRM). Change them all to Blocking assigns inside seq::body and try.
Good Luck
Srini
www.verifworks.com
In reply to Srini @ CVCblr.com:
Thank you… That helped.
