Does UVM IEEE supports “uvm_path_e” ?
Iam observing syntax error
rror-[SE] Syntax error
token ‘uvm_path_e’ should be a valid type. Please declare it virtual
if it is an Interface
In reply to abhilash.20:
By looking at the 2017 IEEE code I can see the following:
// Variable -- NODOCS -- default_path
// Default access path for the registers and memories in this block.
`ifdef UVM_ENABLE_DEPRECATED_API
uvm_door_e default_path = UVM_DEFAULT_DOOR;
`else
local uvm_door_e default_path = UVM_DEFAULT_DOOR;
`endif
So it looks it has been deprecated/replaced by uvm_door_e. This example may help you
HTH,
-R
Hey i believe is still supported since ral model does support uvm path as backdoor user and not user and frontdoor
In reply to Rsignori92:
I think got changed as mentioned in this presentation slide 65
“uvm_path_e type became uvm_door_e
– UVM_DEFAULT_PATH UVM_DEFAULT_DOOR”
-R
