Hi What is the difference between get_sequence_id() and get_transaction_id() in uvm?
In reply to srikanthen:
Get_sequence_id is an internal method that is not intended for user code. The sequence_id is not a simple integer. The get_transaction_id is meant for users to identify specific transactions.
These methods allow access to the sequence_item sequence and transaction IDs. get_transaction_id and set_transaction_id are methods on the uvm_transaction base_class. These IDs are used to identify sequences to the sequencer, to route responses back to the sequence that issued a request, and to uniquely identify transactions.
The sequence_id is assigned automatically by a sequencer when a sequence initiates communication through any sequencer calls (i.e. `uvm_do_xxx, wait_for_grant). A sequence_id will remain unique for this sequence until it ends or it is killed. However, a single sequence may have multiple valid sequence ids at any point in time. Should a sequence start again after it has ended, it will be given a new unique sequence_id.
The transaction_id is assigned automatically by the sequence each time a transaction is sent to the sequencer with the transaction_id in its default (-1) value. If the user sets the transaction_id to any non-default value, that value will be maintained.
Responses are routed back to this sequences based on sequence_id. The sequence may use the transaction_id to correlate responses with their requests.
set_transaction_id
function void set_transaction_id(
integer id
Sets this transaction’s numeric identifier to id. If not set via this method, the transaction ID defaults to -1.
When using sequences to generate stimulus, the transaction ID is used along with the sequence ID to route responses in sequencers and to correlate responses to requests.
get_transaction_id
function integer get_transaction_id()
Returns this transaction’s numeric identifier, which is -1 if not set explicitly by set_transaction_id.
When using a uvm_sequence #(REQ,RSP) to generate stimulus, the transaction ID is used along with the sequence ID to route responses in sequencers and to correlate responses to requests.
