Difference between get_next_item and get?
what is the differnce between get_next_item and get?
In reply to lalithjithan:
Both methods retrieving a seq_item from the sequencer. get_next_item needs an item_don() call after the seq_item has been processed. get does not Need this, but you can pass a rsp back to the sequencer by using put(rsp).
So which is good to use get() or get_next_item()?
I mean what are advantages and disadvantages of using them?
In reply to chaitanya_i:
You can use both. There is no Limitation or disadvantage. But you should be consistent, not using both in your UVM environment.
get_next_item() is a blocking call, where-as get() is a non-blocking call.
get() is used in cases, where the given protocol/interface supports pipe-lining.
Refer “Driver/Pipelined” section of UVM cookbook for an example of get()/put().
In reply to S.P.Rajkumar.V:
I have to correct you, get(9 and put() are always blocking!
I meant blocking and non-blocking in the context of handshake mechanism between the sequence, seqeuncer and driver. May be the word “call” with blocking and non-blocking has created the confusion.
To clarify it:
In get_next_item()+item_done() case, the sequencer is blocked and the driver cannot request a new item until the current_item is processed and item_done is sent.
Where-as, in get()+put() way, the sequencer is unblocked with the get() call itself and the driver can always do another get() even before the first put() is completed.
Thanks for the explanation. One more thing I want to clarify is that this response will happen only when we want the connection between the sequencer and driver to be bi-directional. Otherwise, get() is enough to insert into the code, right?
