In the following code ::
`include "uvm_pkg.sv"
`include "uvm_macros.svh"
`define COMP_NEW function new ( string name , uvm_component parent ) ; \
super.new(name,parent);\
class trans ;
rand bit [2:0] addr ;
class Producer extends uvm_component ;
`uvm_component_utils(Producer)
uvm_blocking_put_port #(trans) put_port ;
`COMP_NEW
put_port = new("put_port",this);
task main_phase ( uvm_phase phase ) ;
trans txn ;
phase.raise_objection(this);
txn = new();
txn.randomize();
put_port.put(txn);
phase.drop_objection(this);
typedef class Consumer ;
class Consumer_ext extends Consumer ;
`uvm_component_utils(Consumer_ext)
`COMP_NEW
task put ( trans t ) ;
$display(" %0s Received %0p",get_name(),t);
class Consumer extends uvm_component ;
`uvm_component_utils(Consumer)
uvm_blocking_put_imp #(trans,Consumer ) put_imp ;
Consumer_ext ext ;
`COMP_NEW
put_imp = new("put_imp",ext); // Delegates put() implementatn to extended component [Q]Should be 2nd why ?
ext = new("ext",this);
virtual task put ( trans t );
$display(" Received %0p",t);
class env extends uvm_component ;
`uvm_component_utils(env)
`COMP_NEW
Consumer cons ;
Producer prod ;
cons = new("cons",this);
prod = new("prod",this);
function void connect_phase ( uvm_phase phase ) ;
prod.put_port.connect(cons.put_imp) ;
[Q] The above code doesn’t work ( ext needs to be instantiated before put_imp ) .
I was under the impression that since at run-time the methods would be called , by which all components would be created so the order shouldn’t be important .
**Why is it that the order actually matters ?**
