Delaying the start of scoreboard
I am trying to make APB VIP.
However I am stuck at scoreboard-
The idea is to delay the scoreboard start until the monitor has sent all the transactions (5 writes, 5 reads) to Scoreboard.
I tried the Delay method in run phase and it’s working fine but I want something which can be true for every test.
Is there a way to check the last transaction in sequence or monitor and then trigger an event from there to start the scoreboard ?
SR
MONITOR:
	apb_transaction apb_tx_mon;
	apb_tx_mon = apb_transaction::type_id::create("apb_tx_mon", this);
	@(posedge apb_vin.clk)
		if (apb_vin.penable)
			apb_tx_mon.paddr 	= apb_vin.paddr;
			apb_tx_mon.pwdata	= apb_vin.pwdata;
			apb_tx_mon.pwrite	= apb_vin.pwrite;
			if (!apb_vin.pwrite) begin
		#1;	apb_tx_mon.prdata	= apb_vin.prdata;
			`uvm_info("MONITOR", "CALLING WRITE METHOD", UVM_MEDIUM);
			apb_mon_ap.write(apb_tx_mon);
SCOREBOARD:
task run();
#420;
	int i;
	i= sb_fifo.used();
	while(sb_fifo.used() != 0)
	`uvm_info("SCOREBOARD", $sformatf("fifo size: %0d ", sb_fifo.used()), UVM_MEDIUM);
	sb_fifo.get(apb_tx);
	//`uvm_info("SCOREBOARD_PRINT", $sformatf("paddr=%0d, prdata=%0d, pwdata=%0d, pwrite=%0d", apb_tx.paddr, apb_tx.prdata, apb_tx.pwdata, apb_tx.pwrite), UVM_MEDIUM);
		if (!apb_tx.pwrite)
		`uvm_info("SCOREBOARD", $sformatf("pwrite= %0d", apb_tx.pwrite ), UVM_MEDIUM);
		compare(apb_tx);
		else
			write_box.put(apb_tx);
	end[.](https://verificationacademy.com)
In reply to mrlee:
You should never have to delay the start of your scoreboard. The get() method of the uvm_tlm_analysis_fifo is blocking, so your scoreboard should block until it receives an item in the appropriate fifos.
In reply to cgales:
In addition what Chuck is saying. Your monitor might publish transactions which are not relevant, i. e. extracted when no useful response is available.
Make your monitor sending out only useful responses.
