Deciding REQ and RSP type parameters for Driver , Sequence and Sequencer in RAL
Hi ,
[X] Depending on whether there is a response for the Request driven on interface we have Unidirectional and Bidirectional protocols .
[Y] During specialization of REQ and RSP type parameters of sequence , sequencer and driver , the user has 2 options ::
 (a)  REQ  and  RSP  are  same . In  this  case  response  fields  are  part  of  Request item  i.e  REQ  type  for  bidirectional  protocols .
          //  After  assigning  the  response  fields  of  the  Request  item  fetched  by  driver .
          seq_item_port.item_done( req ); //  Used  with  seq_item_port.get_next_item( req ) ;
                  [ OR ]
          seq_item_port.put( req );       //  Used  with  seq_item_port.get( req ) ;
 So  when  driver  sends  response  back  it  would  simply  assign  the  response  fields  on  observing a response on the bus for the request previously driven on interface .
 (b)  REQ  and  RSP  are  different . In  this  case  , driver  creates  response  item  ' rsp ' , assigns  it's  fields  and  then  calls  ::
          seq_item_port.item_done( rsp ); //  Used  with  seq_item_port.get_next_item( req ) ;
                  [ OR ]
          seq_item_port.put( rsp );       //  Used  with  seq_item_port.get( req ) ;
Within UVM class uvm_reg_map tasks ’ do_bus_write ’ and ’ do_bus_read ’ we have the following code ::
      adapter.m_set_item(rw);
      bus_req = adapter.reg2bus(rw_access);
      adapter.m_set_item(null);
      if (bus_req == null)
        `uvm_fatal("RegMem",{"adapter [",adapter.get_name(),"] didnt return a bus transaction"});
      bus_req.set_sequencer(sequencer);
      rw.parent.start_item(bus_req,rw.prior);
      if (rw.parent != null && i == 0)
        rw.parent.mid_do(rw);
      rw.parent.finish_item(bus_req);
      bus_req.end_event.wait_on();         //  Raised  a  separate  Forum  thread  to  discuss  working  of  this  line  of  code .
      if (adapter.provides_responses) begin
        uvm_sequence_item bus_rsp;
        uvm_access_e op;
        // TODO: need to test for right trans type, if not put back in q
        rw.parent.get_base_response(bus_rsp);   //  [ST1]
        adapter.bus2reg(bus_rsp,rw_access);     //  [ST2]
      else begin
        adapter.bus2reg(bus_req,rw_access);     //  [ST3]
[1] If bit property ’ provide_responses ’ of the adapter is set ( 1 ) , driver sends responses back ( Refer Y above )
 So  via  [ST1]  the  response  would  be  fetched  above  and  then  calls  adapter  function  ' bus2reg '  **with  the  response  fetched  passed as  1st  argument .**
**[Q1] Does  this  place  any  restriction  on  the  REQ  and  RSP  type  parameters  i.e  should  it  be  same  or  different type ?**
[2] If bit property ’ provide_responses ’ of the adapter is at default ’ 0 ’ , it means the driver doesn’t send responses back .
However if driver uses seq_item_port.get_next_item( req ) and seq_item_port.item_done( req ) , driver could still update response fields within request item .
( provided REQ and RSP types are same ).
So  when  **finish_item( req )  unblocks  it  would  contain  the  updated  response  fields**
[Q2] Depending on the bus protocol it could be either unidirectional or bidirectional protocol .
  [ST1]  executes  for  birectional  protocol  whereas [ST3]  would  execute  for  either  case .
( For bidirectional protocol the response fields could be part of REQ item and assigned before calling seq_item_port.item_done( req ) )
 **Please  correct  me  if  wrong .**
[3] Within function ’ bus2reg ’ variable ’ status ’ of struct ’ uvm_reg_bus_op ’ of ref argument ’ rw ’ is assigned
      virtual function void bus2reg(uvm_sequence_item bus_item, ref uvm_reg_bus_op rw);
           rw.status =  //  Assign  UVM_IS_OK / UVM_HAS_OK / UVM_NOT_OK
      endfunction: bus2reg
[Q3] Doesn’t this restrict that the bus protocol must always be bidirectional ( i.e response is present ) since there is a result of the transaction ?
What if variable ’ status ’ isn’t assigned ? ( default is UVM_IS_OK for the typedef ) . Would there be any side-effects if not assigned explicitly ?
