Debugging source of Warnings during Factory registration
`include "uvm_macros.svh"
`include "uvm_pkg.sv"
 import uvm_pkg::* ;
`define COMP function new( string name , uvm_component parent );\
                 super.new(name,parent);\
 module  Registering_Matching_Types_L3  ;
   class  Type_Comp #( type T = int )  extends  uvm_test ;
  typedef  uvm_component_registry #( Type_Comp #( T ) , "Type_Comp" ) type_id ;  //  NOTE  ::  Same 'Tname'  for  different  Specialization  !!
      `COMP
      function   void    build_phase  (  uvm_phase  phase )  ;
         `uvm_info(get_name , $sformatf(" In build_phase() ") , UVM_NONE )
    //  Specialization  for  Registration  !!
    Type_Comp #( int )   type_int ;
    Type_Comp #( bit signed [31:0] )   type_bit_sign ;
    initial  begin
      run_test("Type_Comp") ;
I get Warning Messages as the String Registration is same for all Specializations of class Type_Comp
I went through Source Code for function register of class uvm_factory ::
   function void uvm_default_factory::register (uvm_object_wrapper obj);  //  obj  points  to  Extended  uvm_component / uvm_object  !!
  if (obj == null) begin
    uvm_report_fatal ("NULLWR", "Attempting to register a null object with the factory", UVM_NONE);
  if (obj.get_type_name() != "" && obj.get_type_name() != "<unknown>") begin
    if (m_type_names.exists(obj.get_type_name()))  //    This  is  Simple  to  Understand  . Basically  Tname  for  Components  should  be  Unique
      uvm_report_warning("TPRGED", {"Type name '",obj.get_type_name(),
        "' already registered with factory. No string-based lookup ",
        "support for multiple types with the same type name."}, UVM_NONE);
    else
      m_type_names[obj.get_type_name()] = obj;
  if (m_types.exists(obj)) begin        //   Need  help  here  !!
      uvm_report_warning("TPRGED", {"Object type '",obj.get_type_name(),
                         "' already registered with factory. "}, UVM_NONE);
  else begin
    m_types[obj] = 1;
My Question is when would :: if (m_types.exists(obj)) begin be True ??
 **Can  someone  provide a  example  when  I could  see the  Warning  during  Type  Registration  ?**
I expected that since ‘int’ and ‘bit signed [31:0]’ are Matching types
I would Observe Warning Message during Type Registration , but I don’t
In reply to TC_2017:
This is leftover from OVM when some tools did not support the typedef uvm_component_registry mechanism for factory registration. It needed to construct an object and have the static initialization call uvm_factory::register.
I suppose register() can still be used to register a class with the factory from outside that class. I can think of a number of ways you might inadvertently register the same class twice.
Could you please elaborate on it via a code snippet .
Too rare to worry about in my option.
