Creating multiple handles for covergroup in new constructor
class A;
covergroup cg;
endgroup
extern function new(string name, uvm_component parent);
function A::new(string name, uvm_component parent);
super.new(name,parent);
cg cg_tx = new;
cg cg_rx = new;
For the above code I am getting the error,
10: token is ‘cg_tx’
cg cg_tx = new;
I want multiple handles of covergroup ‘cg’ created say cg_tx and cg_rx. How can this be done?
When you have an embedded covergroup (declare a covergroup inside the class), the covergroup object and class object are merged into a single object. That is why the cg constructor has to be inside the class constructor, and you are not allowed to declare multiple instances of an embedded covergroup.
If you really want multiple covergroup instances for a single class object, you will have to declare the covergroup outside the class, and pass all the coverpoint data through arguments to the covergroup’s constructor.
Hi Dave,
Please provide more information on what you mean by outside of the class?
If possible, provide a simple example.
it will be great.
Thanks.
In reply to SKUPPAM:
https://verificationacademy.com/forums/coverage/creating-new-instances-covergroup-using-array.#reply-41565
Thanks Dave, it helped.
Tried a simple example. might be helpful others.
Dave, correct me if anything wrong in the usage.
class x;
int y;
covergroup x2 (ref x z1);
option.per_instance = 1;
coverpoint z1.y {
bins x1 = {3};
endgroup
class cg;
x t;
x2 t1,t2;
function new ();
t=new();
t1 = new(t);
t2 = new(t);
call();
join_none
task call ();
int cnt ;
repeat (40) begin
t.y = cnt;
if (cnt [0]) t1.sample();
if (!cnt [0]) t2.sample();
cnt = cnt +1;
#10;
$display (“sample \n”);
module tb;
cg q1;
q1 = new();
#10000;
$finish;
$display (“done”);
I try to understand what your objective is, having two instances of the same covergroup in one component. Would be great if you could say a few words regarding this.
Christoph
SOrry if it had created a confusion.
The example is a trial to check, if i am able to create two instances by moving the CG outside or not. its just a dummy.
But, i want to use this concept in cases of multiple channels and separate it by id’s.
You did not create confusion. But I was doing about 20 OVM and UVM projects with very different applications during the last years and I was never facing a topic like yours. But of course it is an interesting topic.
Coverage collection is a theme where the UVM User Guide does not give clear guidelines.
My project practice showed a good place for placing a functional coverage collector is in the agent. This way you can at least measure what was generate by the sequencer. My agents have always a sequencer/driver and a monitor/coverage collector pair. Following this advice you would not need several instances of the same coverage collector outside of an agent.
Hi Skuppam,
Did your example work? i understand that you are passing the class itself as a reference to the covergroup.
Am also trying to declare covergroup outside class and declaring multiple coverpoints inside covergroup. how do i make this work? please give a working example.
With Regards
Ajay
In reply to Ajay2112:
The example that i have given above worked and i dont have any issue
hi
I am using embedded cover group in my TB,
class baby_coverage extends uvm_subscriber #(baby_pkt);
  `uvm_component_utils(baby_coverage)
   uvm_analysis_imp #(baby_pkt,baby_coverage) baby_coverage_imp;
  covergroup baby_covergroup;
	//                COVERPOINTS
	coverpoint pktt.READ_FROM_INVALID_STATE
				bins PIPE_0_READ_FROM_INVLAID[] = { 	pktt.DADY_0_PIPE_0_baby_RD_FROM_INVALID,
													pktt.DADY_1_PIPE_0_baby_RD_FROM_INVALID,
													pktt.DADY_2_PIPE_0_baby_RD_FROM_INVALID,
													pktt.DADY_3_PIPE_0_baby_RD_FROM_INVALID,
													pktt.DADY_4_PIPE_0_baby_RD_FROM_INVALID,
													pktt.DADY_5_PIPE_0_baby_RD_FROM_INVALID,
													pktt.DADY_6_PIPE_0_baby_RD_FROM_INVALID,
													pktt.DADY_7_PIPE_0_baby_RD_FROM_INVALID
				bins PIPE_1_READ_FROM_INVLAID[] = { 	pktt.DADY_0_PIPE_1_baby_RD_FROM_INVALID,
													pktt.DADY_1_PIPE_1_baby_RD_FROM_INVALID,
													pktt.DADY_2_PIPE_1_baby_RD_FROM_INVALID,
													pktt.DADY_3_PIPE_1_baby_RD_FROM_INVALID,
													pktt.DADY_4_PIPE_1_baby_RD_FROM_INVALID,
													pktt.DADY_5_PIPE_1_baby_RD_FROM_INVALID,
													pktt.DADY_6_PIPE_1_baby_RD_FROM_INVALID,
													pktt.DADY_7_PIPE_1_baby_RD_FROM_INVALID
				bins PIPE_2_READ_FROM_INVLAID[] = { 	pktt.DADY_0_PIPE_2_baby_RD_FROM_INVALID,
													pktt.DADY_1_PIPE_2_baby_RD_FROM_INVALID,
													pktt.DADY_2_PIPE_2_baby_RD_FROM_INVALID,
													pktt.DADY_3_PIPE_2_baby_RD_FROM_INVALID,
													pktt.DADY_4_PIPE_2_baby_RD_FROM_INVALID,
													pktt.DADY_5_PIPE_2_baby_RD_FROM_INVALID,
													pktt.DADY_6_PIPE_2_baby_RD_FROM_INVALID,
													pktt.DADY_7_PIPE_2_baby_RD_FROM_INVALID
				bins PIPE_3_READ_FROM_INVLAID[] = { 	pktt.DADY_0_PIPE_3_baby_RD_FROM_INVALID,
													pktt.DADY_1_PIPE_3_baby_RD_FROM_INVALID,
													pktt.DADY_2_PIPE_3_baby_RD_FROM_INVALID,
													pktt.DADY_3_PIPE_3_baby_RD_FROM_INVALID,
													pktt.DADY_4_PIPE_3_baby_RD_FROM_INVALID,
													pktt.DADY_5_PIPE_3_baby_RD_FROM_INVALID,
													pktt.DADY_6_PIPE_3_baby_RD_FROM_INVALID,
													pktt.DADY_7_PIPE_3_baby_RD_FROM_INVALID
				bins PIPE_4_READ_FROM_INVLAID[] = { 	pktt.DADY_0_PIPE_4_baby_RD_FROM_INVALID,
													pktt.DADY_1_PIPE_4_baby_RD_FROM_INVALID,
													pktt.DADY_2_PIPE_4_baby_RD_FROM_INVALID,
													pktt.DADY_3_PIPE_4_baby_RD_FROM_INVALID,
													pktt.DADY_4_PIPE_4_baby_RD_FROM_INVALID,
													pktt.DADY_5_PIPE_4_baby_RD_FROM_INVALID,
													pktt.DADY_6_PIPE_4_baby_RD_FROM_INVALID,
													pktt.DADY_7_PIPE_4_baby_RD_FROM_INVALID
				bins PIPE_5_READ_FROM_INVLAID[] = { 	pktt.DADY_0_PIPE_5_baby_RD_FROM_INVALID,
													pktt.DADY_1_PIPE_5_baby_RD_FROM_INVALID,
													pktt.DADY_2_PIPE_5_baby_RD_FROM_INVALID,
													pktt.DADY_3_PIPE_5_baby_RD_FROM_INVALID,
													pktt.DADY_4_PIPE_5_baby_RD_FROM_INVALID,
													pktt.DADY_5_PIPE_5_baby_RD_FROM_INVALID,
													pktt.DADY_6_PIPE_5_baby_RD_FROM_INVALID,
													pktt.DADY_7_PIPE_5_baby_RD_FROM_INVALID
  endgroup : baby_covergroup
  function new(string name = "baby_coverage", uvm_component parent);
    baby_covergroup = new();  //[ERROR]
	$display("baby_covergroup object created");
   baby_pkt pktt;
  virtual function void write (input baby_pkt t1);
	//pktt = t1;
	$cast(pktt,t1.clone());
    baby_covergroup.sample();
    baby_coverage_imp = new("baby_coverage_imp", this);
	$display("baby_coverage_imp object created");
  endfunction : build_phase
for the above code, I am getting NOA [Null object access] error at line
the object at dereference depth 1 is being used before it was constructed/allocated.
make sure that the object is allocated before using it
can anyone help me, this code is syntax correct, I am getting this issue at run time,
In reply to Jintu K Joseph:
Looks like you did not construct the component baby_coverage. Could you please check.
from first reply [When you have an embedded covergroup (declare a covergroup inside the class), the covergroup object and class object are merged into a single object. That is why the CG constructor has to be inside the class constructor, and you are not allowed to declare multiple instances of an embedded covergroup.] so I think we need not construct the object for this case,
If construct the object like
baby_covergroup baby_covergroup;
I am getting a compilation error, this usage is not allowed
I am getting the error when I am creating the object[ baby_covergroup = new(); //[ERROR]
I asked for the component baby_coberage which is a component having in the baby_covergroup.
Please use code tags. I have added them for you.
You are referencing pktt in your covergroup. You will need to create a handle for pktt prior to creating your covergroup:
baby_pkt pktt;
  pktt = new("pktt");
In reply to cgales:
I have updated the code as follows, still facing same NOA error:
baby_pkt pktt;
// COVERPOINTS
bins PIPE_0_READ_FROM_INVLAID = {
bins PIPE_1_READ_FROM_INVLAID = {
bins PIPE_2_READ_FROM_INVLAID = {
bins PIPE_3_READ_FROM_INVLAID = {
bins PIPE_4_READ_FROM_INVLAID = {
bins PIPE_5_READ_FROM_INVLAID = {
function new(string name = “baby_coverage”, uvm_component parent);
$display(“baby_covergroup object created”);
//pktt = t1;
baby_coverage_imp = new(“baby_coverage_imp”, this);
$display(“baby_coverage_imp object created”);
A few other things you should clean-up before continuing with your construction problem.
(1) the uvm_subscriber class has itself a built-in analysis_export/imp. You do not have to add another one explicitly.
(2) the write function of the analysis_export/imp is a pure virtual function, i.e. the prototype lokks like this:
pure virtual function void write( T t). The argumnet name is t and not t1 as you are using.
Please correct these issues and modify the connection to the buil-in analysisi_port in the right way.
Look at my previous response. You need to create pktt prior to creating the covergroup.
In reply to cgales:
I tried this too, still getting same issue
Could you please share some more code, best would be the whole example.
If you do not want to share with the community you can send it to my email address
christoph@christoph-suehnel.de
