I am trying to write a coverage for enum which is dynamic array and i am not able to completely write it. Here is my code. Can anyone help me?
typedef enum bit[1:0] {IDLE, BUSY, NONSEQ, SEQ} transfer_t;
In transaction class
rand transfer_t trans_type[];
Coverage class :
covergroup transfer with function sample (transfer_t ty);
TRANS: coverpoint ty;
endgroup
// comp_b has a imp port where we need to implement the put method.
class comp_b extends uvm_component;
`uvm_component_utils (comp_b)
transfer txy;
uvm_blocking_put_imp #(transaction,comp_b) trans_in;
function new (string name = "comp_b", uvm_component parent);
super.new(name,parent);
txy = new();
trans_in = new("trans_in",this);
task put (transaction tx);
#100;
`uvm_info(get_type_name(),$sformatf(" Recived trans On comp_b "),UVM_LOW)
`uvm_info(get_type_name(),$sformatf(" trans, \n %s",tx.sprint()),UVM_LOW)
txy.sample(transfer_t'(tx.trans_type));
Link to code :
https://edaplayground.com/x/ht9S
