In reply to nitishg:
With UVM 1.2, try using the command line option +uvm_set_config_int=comp,field,value in conjunction with uvm_config_db#(uvm_bitstream_t)::get( cntxt, inst_name, field_name, value )
package pkg;
`include "uvm_macros.svh"
class B extends uvm_sequence;
bit C = 1'b1;
`uvm_object_utils(B)
function new(string name="B");
virtual task pre_start();
void'(uvm_config_db#(uvm_bitstream_t)::get(null,get_full_name(),"C",C) );
virtual task body();
`uvm_info( "TRACE", $sformatf( "C=%b", C ), UVM_LOW )
class test extends uvm_test;
uvm_sequencer#(uvm_sequence_item) sqr;
`uvm_component_utils(test)
function new( string name="test", uvm_component parent=null );
super.new( name, parent );
virtual function void build_phase( uvm_phase phase );
sqr = new("sqr", this); // cheat, factory not setup for this example type
virtual task run_phase( uvm_phase phase );
B b;
b = B::type_id::create( "b", this );
b.start( sqr );
endpackage
module top;
import pkg::*;
initial run_test("test");
**sim-cmd**[pre]UVM_INFO @ 0: reporter [RNTST] Running test test...
UVM_INFO config_db.sv(21) @ 0: uvm_test_top.sqr@@b [TRACE] C=1
[/pre]
**sim-cmd "+uvm_set_config_int=uvm_test_top.sqr.b,C,1"**[pre]UVM_INFO @ 0: reporter [RNTST] Running test test...
UVM_INFO @ 0: reporter [UVM_CMDLINE_PROC] Applying config setting from the command line: +uvm_set_config_int=uvm_test_top.sqr.b,C,1
[/pre]
**sim-cmd "+uvm_set_config_int=uvm_test_top.sqr.b,C,0"**[pre]UVM_INFO @ 0: reporter [RNTST] Running test test...
UVM_INFO @ 0: reporter [UVM_CMDLINE_PROC] Applying config setting from the command line: +uvm_set_config_int=uvm_test_top.sqr.b,C,0
UVM_INFO config_db.sv(21) @ 0: uvm_test_top.sqr@@b [TRACE] C=0
[/pre]
Mr. Lazy prefers to replace "C" with a globally unique name, so you can just do this.
[br]**sim-cmd "+uvm_set_config_int=*,C,0"**[pre]UVM_INFO @ 0: reporter [RNTST] Running test test...
UVM_INFO @ 0: reporter [UVM_CMDLINE_PROC] Applying config setting from the command line: +uvm_set_config_int=*,C,0
UVM_INFO config_db.sv(21) @ 0: uvm_test_top.sqr@@b [TRACE] C=0[/pre]
