Controlling the random seed for a verification env with UVM
I have these questions.
1] how to establish a random seed for a verification env with UVM?
2] what is the difference between using the $srandom(x) system function and passing the seed directly to $random(seed) or $urandom(seed)?
3] how is the seed applied in case using the method randomize()?
In reply to samerh:
  1. The seed for SystemVerilog simulation can be set by the command line of your tool. Please check the User Manual.
  2. $random is from Verilog and you should no longer be using it.
  3. $urandom and randomize are both controlled by the same SystemVerilog seeding mechanism. A good pair on this subject can be found here.
