Hi ,
I see that sub-components could be created inside the constructor but in all codes/examples I see that build_phase is used .
Why is it so ?
I read following lines regarding the same but couldn’t understand it ::
Allocate all sub-components in the build_phase rather than the constructor allows component to be configured before it allocates the hierarchy underneath it . Since constructor isn't polymorphic , it is not possible for a derivative class to change the structure unless the structure is created in the build function .
Need help with the above lines .
Also config_db;;get() is widely used in build_phase , could using “this” as argument to config_db::get() called inside the constructor cause any issues ?
In reply to MICRO_91:
When extending a class, you can only append statements to the constructor since calling super.new() must be the first statement of any class constructor except for the base class
class A;
function new();
statement1;
class B extends A;
function new();
super.new();
statement2;
This always results in executing statement1 followed by statement2. But for any other kind of method, you have a choice of where you want to put the call to super.method, or if you want to call it at all.
class
``` verilog
class A;
function new();
statement1;
virtual function void method();
statement1;
class B extends A;
function new();
super.new();
statement2;
statementPre;
if (condition)
super.method();
statementPost;
This comes in very handy when you want to completely replace the build_phase() with new code, not just add to it.
