Hi folks,
I have a BFM which has TLM FIFO’s and uvm_anaylsis_ports and receive and transmit data through these. I need to connect this to another component (a physical layer) but instead of connecting it to another BFM, I need to connect it to the real RTL model. I am trying to find a way to avoid creating an interface for my BFM because it will become obsolete once I have the physical layer BFM with uvm_analysis_ports.
For now, I need to connect my BFM to the actual RTL and test it out. Is it possible to do this without creating an interface? Can I connect my uvm_analysis_ports directly to the RTL ports in the top level ? Something like,
class bfm_top;
BFM.port_1.connect(RTL.port_a);
