Hey all, Hope you’re doing fine.
I’m trying to connect my dut instance that has three interfaces of the the same protocol (IF1 IF2 IF3) to vif ( VIF1, VIF2, VIF3). I don’t know how to connect one interface to another like IF 1 to VIF 1 and so on.
In reply to abdelaali_21:
Not sure if the VIF is your shared virtual interface using config_db or a different type of interface, anyway as long as they use the same interface type port used for the DUT like:
// DUT SIDE
interface if1(input bit clk);
endinterface
interface if2(input bit clk);
endinterface
interface if3(input bit clk);
endinterface
module col(if1 i1, if2 i2, if3 i3);
// TESTBENCH SIDE
interface vif1(input bit clk);
endinterface
interface vif2(input bit clk);
endinterface
interface vif3(input bit clk);
endinterface
module top;
// clock
bit clk;
// test interfaces
if1 vi1(.clk(clk));
if2 vi2(.clk(clk));
if3 vi3(.clk(clk));
// test interfaces
// This will resul into an error due to type mismatch
// vif1 vi1(.clk(clk));
// vif2 vi2(.clk(clk));
// vif3 vi3(.clk(clk));
// DUT
col uut(
.i1(vi1),
.i2(vi2),
.i3(vi3)
// clock gen
always #2 clk = ~clk;
$dumpfile("dump.vcd");
$dumpvars();
#10;
$finish();
