Connecting interface port with the module
Hello, may this question looks basic for some of you ,I verified full adder using some additional inputs and outputs for controllability and observability and i have to verify ripple carry adder .since one of the aims of UVM is reusability i think I can use the module of full adder as it is ,in other words,i can use FA with those additional signals to build RCA .my question:
how to build rca using fa module connected with interface modports ? or I have to build a FA without those additional pins to build rca ?
//////////**** code of FA
module adder(input_if.port inter, output_if.port out_inter,
  output  enum logic [1:0] {INITIAL,WAIT,SEND} state);
    always_ff @(posedge inter.clk)
        if(inter.rst) begin
            inter.ready <= 0;
            out_inter.data <= 'x;
	    out_inter.carry <= 'x;
            out_inter.valid <= 0;
            state <= INITIAL;
        else case(state)
                INITIAL: begin
                    inter.ready <= 1;
                    state <= WAIT;
                WAIT: begin
                    if(inter.valid) begin
                        inter.ready <= 0;
                        out_inter.data <= inter.A ^ inter.B ^ inter.Cin;
			out_inter.carry <= inter.A * inter.B +inter.A * inter.Cin + inter.Cin * inter.B;
                        out_inter.valid <= 1;
                        state <= SEND;
                SEND: begin
                    if(out_inter.ready) begin
                        inter.ready <= 1;
                        state <= WAIT;
        endcase
endmodule: adder
/////***code of interface input
interface input_if(input clk, rst);
    logic  A, B,Cin;
    logic valid, ready;
    modport port(input clk, rst, A, B,Cin, valid, output ready);
endinterface
//////*****code of interface output
    logic  A, B,Cin;
    logic valid, ready;
endinterface
In reply to Imane EL:
You are declaring input_if twice (see your code).
What is the reason for working with input_if and output_if in your module port list.
It is common to have in your case only 1 interface covering all inputs and all outputs.
