I am looking for a clean solution to connect interfaces (and thereby monitors) to internal modules of a DUT. My env looks close to this -
An instance of DUT (dut_inst) has multiple sub-blocks within it. Let’s say we have one such block - blk_a
Let us say blk_a has 3 ports - inputs port1 and port2; output port3
There’s an equivalent interface file defined for blk_a -
interface blk_a_intf (input clk, input rst);
logic port1;
logic [1:0] port2;
logic [2:0] port3;
clocking drv @(posedge clk);
input port1;
input port2;
output port3;
endclocking
clocking mon @(posedge clk);
input port1;
input port2;
input port3;
endclocking
modport driver (clocking drv, input clk, rst);
modport monitor (clocking mon, input clk, rst);
endinterface
The rtl does not use the above interface files. So these get used only in the verification environment to connect properly to the rtl signals.
The modport ‘monitor’ gets used inside the monitor for getting the transaction data. I would like to hook this monitor to the internal block’s (blk_a) ports. Something like -
blk_a_intf.monitor.mon.port1 gets connected to dut.blk_a.port1
blk_a_intf.monitor.mon.port2 gets connected to dut.blk_a.port2
What’s the best way to do this?
