Confusion regarding get_ap of TLM FIFO
Hi all ,
I was going through Class Reference Manual 1.2 uvm_tlm_fifo_base
(I) get_ap :: Transactions passed via get, try_get, peek, or try_peek (via any port connected to the get_peek_export) are sent out this port via its write method.
But when I went through Library Code 1.2 I see that ::
 get_ap.write(t) gets Called in for get() and try_get() Calls .
Even the Simulators Output match the library Code . I am confused regarding this .
  class Component_fifo extends uvm_component ;
  `uvm_component_utils(Component_fifo)
   // We are creating a blocking TLM get port which will fetch a "simple_packet" type of data
   uvm_tlm_fifo #(simple_packet) fifo ; // Constructed in build_phase
      class ComponentB extends uvm_component ;
  `uvm_component_utils(ComponentB)
   uvm_blocking_get_port #(simple_packet) get_port; // Created in build_phase
   simple_packet  pkt;
   function new (string name , uvm_component parent);
   virtual task run_phase (uvm_phase phase);
       forever
           #5;
	   get_port.peek(pkt); // Doesn't call Subs2.write . Why ??
          `uvm_info ("COMPB", "Packet peeked at CompB", UVM_LOW)
	   get_port.get(pkt); // Calls Subs2.write as Expected .
          `uvm_info ("COMPB", "Packet received at CompB", UVM_LOW)
    class Subs2 extends uvm_subscriber #(simple_packet) ;
  `uvm_component_utils(Subs2)
   endfunction: new
   function void write(simple_packet t );
          `uvm_info ("SUBS1", "Packet received at Subs1", UVM_LOW)
  class my_env extends uvm_env;
   `uvm_component_utils (my_env)
       Component_fifo comp_fifo ; // Created in build_phase
       Subs2          subs2;     //  Created in build_phase . Calls write()
   ComponentA     compA ; // Created in build_phase . Does the put()
   ComponentB     compB ; // Created in build_phase . Does the get()
virtual function void connect_phase (uvm_phase phase);
      compA.put_port.connect (comp_fifo.fifo.put_export);
      compB.get_port.connect (comp_fifo.fifo.get_peek_export);
      comp_fifo.fifo.put_ap.connect ( subs1.analysis_export );
      comp_fifo.fifo.get_ap.connect ( subs2.analysis_export );
Is this an issue in Library Code OR Class Reference Manual ?
(II) In uvm_tlm_fifo Class I see flush() Function Implemented as follows ::
  virtual function void flush();
    T t;
    bit r;
    r = 1;
    while( r ) r = try_get( t ) ;
    if( m.num() > 0 && m_pending_blocked_gets != 0 ) begin
      uvm_report_error("flush failed" ,
		       "there are blocked gets preventing the flush", UVM_NONE);
I believe the try_get() Calls recursively till all elements are removed from Mailbox ( inside tlm_fifo ) .
My doubt is regarding the uvm_error’s Condition .
When would it be true ? i.e
m_num() is an int same as the size argument passed to new() and m_pending_blocked_gets is Simply a Counter that Increments on calls to get() and on getting a transaction decrements its count back to 0
Thanks in advance ,
ABD
In reply to ABD_91:
The first issue is fixed in the IEEE 1800.2 LRM, however I think it is a bug in the library that flush() should indirectly call write(). I’ve filed a bug report.
The second issue is already filed as a bug(s).
